dust collector
Forum topic by sailorjo70 posted 03-22-2012 02:41 PM 1115 views 0 times favorited 5 replies Add to Favorites Watch
View sailorjo70's profile
sailorjo70
24 posts in 2544 days
03-22-2012 02:41 PM
hello all you good lumber jocks could some one tell me if dryer plastic hose is safe to use on 2 hp dust collector
-- george Nl,Canada
5 replies so far
View Radu's profile
Radu
330 posts in 3243 days
#1 posted 03-22-2012 02:43 PM
I’d say no. It will collapse in no time.
View crank49's profile
crank49
4032 posts in 3171 days
#2 posted 03-22-2012 03:09 PM
No. Its for positive pressure applications.
Suction hose is very different.
View BlankMan's profile
BlankMan
1490 posts in 3553 days
#3 posted 03-22-2012 03:15 PM
Just an FYI, you want to try to use as little flexible hose as possible what ever type it is, the ridges in it produce really high losses. I only use it in the last 6” connecting the metal pipe to the gate on the machine. Did the same thing when I used PVC pipe.
-- -Curt, Milwaukee, WI
View Grandpa's profile
Grandpa
3261 posts in 2875 days
#4 posted 03-22-2012 07:51 PM
A good vacuum system will collapse a metal pipe so a dryer hose would be out of the question. Buy a joint of it and use it sparingly as suggested above. It is a splice at best and probably a poor one at that.
sailorjo70
#5 posted 03-25-2012 12:27 AM
Iwould like to thank all my good LJ for there advice
-- george Nl,Canada
