Pinning cutting boards for glue ups
Forum topic by AandCstyle posted 03-22-2012 12:05 PM 2099 views 0 times favorited 9 replies Add to Favorites Watch
View AandCstyle's profile
AandCstyle
3185 posts in 2497 days
03-22-2012 12:05 PM
I have seen a few references to people using a pin nailer to prevent a glue up from sliding around while the glue sets. As I understand it, a pin is nailed into one side leaving it about 1/4 inch proud, the glue is applied then a clamp is used to squeeze the 2 parts together. Obviously, alignment during the last part is critical.
My questions are:
1. Is this really a good way to hasten the gluing process? Is it more trouble than it is worth?
2. Do I have the procedure correct?
3. Do people use an 18G brad and cut the head off or use a 23G pin?
4. If this isn’t the correct forum, which one is?
TIA for all comments and suggestions.
A&C Style
-- Art
9 replies so far
View GrandpaLen's profile
GrandpaLen
1651 posts in 2512 days
#1 posted 03-22-2012 01:11 PM
An 18G Brad Nailer is would be overkill on a cutting board.
A 23G Pinner would be much better, but you won’t leave it proud of the surface. You would pin each segment to the next after applying the glue.
I have used the small brad standing proud with the head snipped off to stablize wider boards when glueing face to face but those would have to be driven in by hand and in my opinion not so good for your application.
The use of a pin nailer frees up clamps if you need them elsewhere but you would still use clamps while pinning and glueing segments together.
Glue, clamp, pin, remove clamps and repeat.
Best wishes for a successful build.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3720 days
#2 posted 03-22-2012 02:12 PM
I just use Bessey K body clamps and no nails. That seems to work fine. If I have a lot of pieces I sometimes glue 4 or 5 strips, then when that sets, I do 4 or 5 more etc.
-- Wayne - Plymouth MN
AandCstyle
#3 posted 03-23-2012 12:39 AM
Thanks for all the input so far. I have and use Bessey K body clamps and still get slippage. I have also tried using curved cauls, but find that I don’t have enough hands to apply 2-3 clamps across the board, a pair of curved cauls on each end (top and bottom) and another pair to hold the keep the ends perfectly aligned. Any other suggestions?
-- Art
SnowyRiver
#4 posted 03-23-2012 12:59 AM
You might be putting too much glue on each strip. I take a stiff brush and level the glue on each piece, lay them on the Bessey clamps, push down with one hand and with the other hand tighten the clamps. I always maike the strips a little thicker than the end product. On a 3/4 inch thick board, I usually use strips about 7/8. Once the glue is dry, I run it through the planer, cut the ends to size, and then finish sand it.
View RickLoDico's profile
RickLoDico
55 posts in 3301 days
#5 posted 03-23-2012 01:49 AM
Sounds like all you need is practice. Dealing with glue and cutting boards gets easier with every board. Don’t bother with the nails.
-- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.
AandCstyle
#6 posted 03-23-2012 02:00 AM
Rick, thanks for the encouragement. I just completed my third and it is okay, but for me the issue is the time consumed in the glue ups. I only glue sets of 2 pieces together at a time to avoid slippage. Then I have to wait a half hour before continuing to the next batch. I am hoping for ways to speed the process.
Art
-- Art
View woody123's profile
woody123
53 posts in 3546 days
#7 posted 03-23-2012 03:32 PM
When I glue my cutting boards together I get a little slippage but I just trim the edges even after the glue dries.
View rkober's profile
rkober
137 posts in 2532 days
#8 posted 03-23-2012 04:02 PM
What has really helped me is a glueing jig or board (or whatever it’s called) to square and clamp against. I’ve seen different configurations but what I have is 3/4” plywood with grooves routed in it and oak pieces on two sides at 90 deg. The board gets waxed so the glue doesn’t stick then you go to work. I glue all the pieces at the same time and use a grooved putty knife so I get uniform spread (just one side in the Wood Whisperer fashion). Turn and clamp with the Bessy K clamps (in both directions against the glue board “fences”). I use a couple straight culls to hold it flat and against the glue board. You still have some planing to do but I’ve had much better luck with this approach.
-- Ray - Spokane, WA - “Most people don’t recognize opportunity because it’s usually disguised as hard work.” - Unknown
AandCstyle
#9 posted 03-24-2012 04:19 AM
rkober, thanks for this tip. I made one and it does help a great deal. The glue ups are definitely easier. Can you provide more info on the grooved putty knife?
-- Art
