Pinning cutting boards for glue ups
Forum topic by AandCstyle posted 03-22-2012 02:06 AM 981 views 0 times favorited 4 replies Add to Favorites Watch
View AandCstyle's profile
3000 posts in 2188 days
03-22-2012 02:06 AM
I have seen a few references to people using a pin nailer to prevent a glue up from sliding around while the glue sets. As I understand it, a pin is nailed into one side leaving it about 1/4 inch proud, the glue is applied then a clamp is used to squeeze the 2 parts together. Obviously, alignment during the last part is critical.
My questions are:
1. Is this really a good way to hasten the gluing process? Is it more trouble than it is worth?
2. Do I have the procedure correct?
3. Do people use an 18G brad and cut the head off or use a 23G pin?
4. If this isn’t the correct forum, which one is?
TIA for all comments and suggestions.
A&C Style
-- Art
View SnowyRiver's profile
51457 posts in 3411 days
#1 posted 03-22-2012 02:26 AM
Probably a good post for the Skill Share Forum.
I havent used a pin nailer for cutting board glue ups. I simply put the pieces in clamps. I usually use the Bessey K body clamps.
-- Wayne - Plymouth MN
View Dusty56's profile
11819 posts in 3619 days
#2 posted 03-22-2012 02:29 AM
Try “woodworking skill sharing”forum : )
View Sawkerf's profile
1730 posts in 2999 days
#3 posted 03-22-2012 03:11 AM
When I make glueups for cutting boards or panels, I get the best alignment I can as I clamp but don’t agonize if something is a little off. When the glue dries, a couple of passes thru the planer makes everything fine.
-- Adversity doesn't build reveals it.
#4 posted 03-22-2012 11:58 AM
Thanks, I will post on the Skill Sharing forum.
-- Art
