Forum topic by Joekwon80 | posted 03-21-2012 08:55 PM | 1493 views | 0 times favorited | 21 replies | ![]() |
Topic tags/keywords: question alignment table saw Just want to get a sense of how often everyone aligns their TS. I’ve never done it but I’ve also never owned a nice saw that was adjustable. Watched some videos of how to do it and got me thinking. So how often do you align your TS? -- Joe Kwon |
21 replies so far
#1 posted 03-21-2012 09:34 PM |
I check it every 3-6 months. Only needed to redo it once. |
#2 posted 03-21-2012 09:37 PM |
hmm…once when I bought it a year ago, and never since. Reminds me that I probably should sometime soon… -- Sometimes the creative process requires foul language. -- Charles Neil |
#3 posted 03-21-2012 09:40 PM |
I aligned my little contractor saw when I first set it up. I check it when I change blades, or load it on the truck for a move. Only had to re-align once(in twelve years, after my helper dropped his end). -- One of these hammers oughta fix that... |
#4 posted 03-21-2012 09:48 PM |
Boy, I can’t even tell you how long I’ve had my Unisaw, 15 years? Might see if I can look that up. But to answer your question, never. I check it ever so often but never had to align it again. -- -Curt, Milwaukee, WI |
#5 posted 03-21-2012 10:01 PM |
Depends on how many other people use it. AND how rough people are on it. I rarely let others on my good saw. I check it if I have to move it. Rarely do I have to make any adjustments. If its cutting smooth and straight…..WHY FIX IT. -- "My mission in life - make everyone smile !" |
#6 posted 03-21-2012 10:39 PM |
When I notice it’s not cutting square. This hasn’t been |
#7 posted 03-21-2012 10:42 PM |
Pretty much like the others, check it every few months but very seldom do I have to adjust it. |
#8 posted 03-21-2012 10:50 PM |
I’ve never had to do anything to mine once I got it set up, adjusted, and alighned from the get-go….My saw never moves, and it’s dead-on accurate on every cut…..It’s been in the same spot going on 3 years.. I bought it in 2009, moved it in, and that’s it…...Rock solid, and dead-on….Actually both of my saws are like that since I’ve got them back-to-back wdith an outfeed between them…...they are there to stay…..!!! -- " At my age, happy hour is a crap and a nap"..... |
#9 posted 03-22-2012 12:17 AM |
As you may have guessed from the answers above, you align it as needed. Checking it is another matter :) I check mine with a gauge about every 6 months, but any time you suspect something might be out of whack you should check. Typically, once properly aligned the saw itself should not go out unless you move it a lot or some other unusual occurrence happens. The fence can more easily go out and should be checked frequently. Ralph -- Watch Woodcademy free on Amazon Prime! www.woodcademy.com |
#10 posted 03-22-2012 12:25 AM |
I check mine when ever I change saw blades.I have adjusted it twice in 15 yrs. |
#11 posted 03-22-2012 12:28 AM |
From the looks of the responses. A good table will not go out of alignment if it’s not whacked or moved too much. That’s good to know. I’m going to be doing all the alignments soon on my project and wanted to gauge how much one of those alignment tools would come in hand. I guess I’ll be skipping the alignment tool! -- Joe Kwon |
#12 posted 03-22-2012 12:58 AM |
Joe – no fancy tools needed. A simple combination square can be used. Just place the short edge in the miter slot and line up the end of the rule with the blade and run it back and forth sliding in the miter slot. Distance to the blade should be constant. Turn it around and measure from the miter slot to the fence. You’re not looking for the absolute distance, just the variation along the length of the fence. It takes only a couple of minutes to do this check and while not super precise, if the rule comes away from the fence or the blade at all, you’ll know it. -- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible. |
#13 posted 03-22-2012 01:12 AM |
I aligned my old Crapsman just once in 20 years. I now have a used Ridgid 4511 which I am restoring. -- "Of all the things I have lost in life, I miss my mind the most." |
#14 posted 03-22-2012 01:32 AM |
I aligned once….check it every now and then. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#15 posted 03-22-2012 01:36 AM |
Good timing. I checked mine a couple of days ago. After about 18 months of usage it hadn’t changed. I did have to make a small adjustment to my sliding compound miter saw – after 3 years. Of course me being the genius that I am I checked them both and after checking them bought new blades. Now I get to do it again. -- Steve - "Never Give Up" |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4903 |
6694 |
28049 |
CNC Woodworking
211 |
Hand Tools
5405 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
