| Forum topic by Bob | posted 430 days ago | 782 views | 0 times favorited | 8 replies | ![]() |
430 days ago |
I have a Shop Fox W1685. I just ordered the Wynn 35A filter kit for it. I also plan on adding a Thien trash can separator. Should I also add a wok to the DC or is that overkill? |
8 replies so far
#1 posted 430 days ago |
The Thein separator is going to get a whole lot of the stuff…maybe consider using it by itself first for awhile, then judge whether you need the wok. My guess (and it is a guess) is that it will be overkill. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#2 posted 430 days ago |
I agree, both would be redundant. The wok takes up less floor space, the Thein in a trash can is easier to empty. -- John |
#3 posted 430 days ago |
You can put the Thien baffle in the ring. It would then take up no more floor space. The downside is that all the chips go through the impeller. It’s also easier to empty the trash can than the bag |
#4 posted 430 days ago |
I definitely think the benefits of the trash can separator outweigh the floor space con. I just wanted to make sure there wasn’t still a significant benefit to adding the wok. So far the consensus appears to be no need for wok if using Thein separator. |
#5 posted 430 days ago |
I added a canister filter to my dc and since I could see the dust swirling around in the lower plastic bag, I could see the dust tornado going up into the filter. I added the wok and just as advertised, the dust cloud stayed in the bottom of the bag. -- Tim-- http://www.tmuli.com |
#6 posted 430 days ago |
After emptying the bag on my single stage Grizzly cartridge DC recently, I was pretty surprised to see how much debri was up in the filter. So I started reading up on putting a Thein plate in my ring, but then came across the wok idea. What are you guys using for your wok? Do you think the wok is significanlty better than putting a Thein plate in your ring? I do not have space for a trash can addition. -- Matt, Pine is fine, but Oak's no joke! |
#7 posted 429 days ago |
I bought a $10 wok at the local grocery store and mounted it across the opening in the ring, using a piece of flat steel. Someone posted awhile back about getting the height of the wok in the ring just right, but I don’t think it makes that much difference. It’s just to disrupt the upward flow of dust and air. -- Tim-- http://www.tmuli.com |
#8 posted 429 days ago |
I think there has been some testing on this and the Thien was better than the wok. The guy had both, tried one, then the other then both, and the Thien did better than the wok, and both only did marginally better than the baffle. I think the test was with the Thein in a trash can, so you never know if it would be different in the ring. Do remember that the filter needs a layer of dust to meet it’s specs. A clean filter doesn’t meet them. |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
