Got my first band saw; What blades should I get?
Forum topic by Everett1 posted 03-20-2012 06:21 PM 1265 views 0 times favorited 7 replies Add to Favorites Watch
View Everett1's profile
Everett1
213 posts in 2618 days
03-20-2012 06:21 PM
Hi Folks,
So, my buddy was walking through Sears, and found this on clearance for $160. Quite a steal IMO:
http://www.sears.com/shc/s/p_10153_12605_00922400000P
I was waiting to get a Grizz 17 inch with the Cast iron wheels, but for $160, hell, I couldn’t say no, and this will open up a lot more things I can do now.
So, I’m going to be getting some Timberwolf blades, but, being a band saw newbie, what blades should I get? I assume maneuvering tight curves is easier with thinner blades, but i figure, I have all this crazy large group of people with so much knowledge, why not just ask what I should get instead of guessing.
So, what blades would people recommend? I would like to maybe make some of my own really thin veneer, and I now have a project of a Maloof rocker as a possiblity now too.
Thanks in advance!
Ev
-- Ev in Framingham, MA
7 replies so far
View Doss's profile
Doss
779 posts in 2348 days
#1 posted 03-20-2012 06:39 PM
My Sears is liquidating right now and I have my eye on a 14”, 12” and 10” bandsaw right now (even though I just bought a 19” Shop Fox).
As far as blades, I’d stick with smaller ones on that saw. I’m not going to say it’s hard to make a veneer with a saw that size, but you’re going to probably need wider blades than that saw can handle.
Again, not saying it can’t be done, but for the types of veneer I envision for my bandsaw (6-12” wide and 4-10’ long), I can’t imagine doing anything similar as far as length is concerned on a smaller saw.
You should get that Grizzly when you get a chance though. It’ll definitely open up your capabilities for the things you’re talking about and you can use the smaller Craftsman for crazy cuts.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View knotscott's profile
knotscott
8100 posts in 3459 days
#2 posted 03-20-2012 06:43 PM
That’s the best price I’ve seen on that saw….got mine for ~ $190 a few years back and thought that was a pretty good deal. I’ve have been pretty happy with it, but you’ll probably want to upgrade the guide bearings…I put ABEC 5 roller blade bearings on mine….$10-$15/15 minutes. I’d call Suffolk Machinery for Timberwolf blades. They’ll ask you what saw you have, and what you cut, then will make recommendations accordingly. They used to offer 4 blades for the price of 3 to new customers…”443” deal.
I agree with Doss…cutting veneer on that saw will be a stretch.
Everett1
#3 posted 03-20-2012 07:03 PM
oh, I agree with the Veneer thing. I also still plan on getting the grizz, this was just too good IMO to pass up.
View interpim's profile
interpim
1170 posts in 3542 days
#4 posted 03-20-2012 07:59 PM
I have noticed that I pretty much stick to the 1/2” 3 tpi blade from Timberwolf for the majority of my work on the bandsaw. You can still cut a pretty nice circle with it, and it is capable of resawing as well.
I just put a 3/4” blade on my saw yesterday, but I wouldn’t use it for anything but resawing or straight cuts.
Timberwolf have been excellent blades… Speaking of that, I have a 1/2” 3tpi blade that is to short for my saw I need to get rid of… I bought a riser and barely even used it. It’s a 93 1/2” blade length.
-- San Diego, CA
View JAAune's profile
JAAune
1825 posts in 2400 days
#5 posted 03-22-2012 12:16 AM
3TPI is good. I’d not recommend a blade that has more teeth than that unless you need something smaller than a 1/2” blade and can’t find one with low TPI. Like Interpim, I mostly use 1/2” 3 TPI blades since they are highly versatile.
View MoshupTrail's profile
MoshupTrail
304 posts in 2564 days
#6 posted 03-22-2012 12:46 AM
Generally speaking more TPI gives a smoother cut. 3 TPI is good for ripping. I love ripping rough lumber with my bandsaw – so much safer than the TS. If you plan to resaw dry wood go for a Woodslicer. I got one of those, and while it’s not recommended for wet wood, the job it does in dry boards is unbelievable. The 3TPI Timberwolf will rip up a small log into boards you can dry and then mill.
So what do you think you’ll be doing?
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
View cutworm's profile
cutworm
1075 posts in 2877 days
#7 posted 03-22-2012 01:43 AM
I bought a Carter 1/2” blade on Amazon a while back and really like it. Very smooth and cuts fast with nearly no force.
-- Steve - "Never Give Up"
