Belt Drive for Rigid 4511
Forum topic by lieutenantdan posted 03-20-2012 06:18 PM 1032 views 0 times favorited 4 replies Add to Favorites Watch
View lieutenantdan's profile
lieutenantdan
176 posts in 2175 days
03-20-2012 06:18 PM
Anyone using a belt system (i.e. replacement pulleys and belt) different from the original?? If you are using the original pulleys and belt, where are you getting your replacement belt when needed??
-- "Of all the things I have lost in life, I miss my mind the most."
View RandyM68's profile
RandyM68
693 posts in 2187 days
#1 posted 03-20-2012 06:26 PM
If it’s a regular V-belt I’d just go to Autozone and find one that is close to the same length. An inch or two either way shouldn’t make any difference. Just make sure it sits in the pulley like the other one does. It’ll be fine. If it will drive your water pump for 100,000 miles, a table saw ain’t nothin’.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View psh's profile
psh
79 posts in 2864 days
#2 posted 03-22-2012 05:04 PM
Google Gates 300J6. It’s the belt that fits the pulleys and the correct size
-- Peter, Central VA
View waho6o9's profile
waho6o9
8064 posts in 2446 days
#3 posted 03-22-2012 06:51 PM
View syenefarmer's profile
syenefarmer
481 posts in 2949 days
#4 posted 03-22-2012 07:24 PM
psh’s recommendation is the correct one. The Ridgid saw takes a serpentine belt so neither a V-belt or a link belt will work on that saw. I take that back, they will work on that saw if you first change out the pulleys.
