Last coat on a coffee table
Forum topic by CantBurn posted 456 days ago 545 views 0 times favorited 5 replies Add to Favorites Watch
View CantBurn's profile
CantBurn
69 posts in 1024 days
456 days ago
Topic tags/keywords: stain seal finish table
So, I refinished a coffee table for my wife. I am actually happy with the way the stain came out. What comes next? I don’t want to throw butcher block oil on it, but I want it to be food safe. So? Do I seal it? With what? Thanks.
-- Chris-Woodstock, Illinois
5 replies so far
View Bill White's profile
Bill White
2650 posts in 2158 days
#1 posted 456 days ago
Coffee table? Food safe?
Any finish will be food safe after it has cured (just my WASO). Use a wiping varnish or wiping poly (Old Masters gel). Let it cure FULLY. Use the table.
Bill
-- bill@magraphics.us
View Caydel's profile
Caydel
12 posts in 457 days
#2 posted 456 days ago
To expand on the above – almost any finish is ‘food safe’ once all the solvents have evaporated.
Note that this can take as much as a month or longer depending on your finish.
View SnowyRiver's profile
SnowyRiver
47525 posts in 1678 days
#3 posted 455 days ago
I would finish it with clear satin polyurethane.
-- Wayne - Plymouth MN
View Dave's profile
Dave
9409 posts in 1037 days
#4 posted 455 days ago
I would use some sand and seal or a 2 pound cut of shellac, 2 coats. Sand between the coats with 400 grit. Then seal it with 3 coats of lacquer. You do not have to sand between the coats of lacquer.
any of the suggested finishes after FULLY dried are fine. Most all kitchen tables sold are lacquer or poly. Its the solvent they are broke down with that is harmful.
The question you need to ask is how hard of a surface do you want. And the ease of application.
oil
shellac
poly
lacquer
IMHO
CantBurn
#5 posted 453 days ago
Thanks for all of the advice guys.
@Bill, I meant by “food safe” because I have three kids and if they are snacking on it, I will feel comfortable with them dropping something on the table and picking it back up and eating it.
