band saw blade, how much play is acceptable
Forum topic by martin007 posted 124 days ago 198 views 0 times favorited 7 replies Add to Favorites
View martin007's profile
martin007
41 posts in 261 days
124 days ago
Hi
I just purchase a band saw, and there is a little forward/backward play in the blade, I tried with 2 different blades. how much play is acceptable or normal.
-- Martin, Gatineau, Québec
View GaryK's profile
GaryK
8486 posts in 474 days
124 days ago
There should be very little if you have your rear bearings set close to the blade.
martin007
124 days ago
It get about 1/32 inch of play
View SM's profile
SM
67 posts in 181 days
124 days ago
Martin,
Play between back bearing and blade should be about the thickness of a dollar bill. (Exchange is close to par so US and Canadian should be the same . . .;-)
I just had someone who works professionally come and check my set up. I thought I had it close but was significantly off. Basically, the bearing should not turn when the saw is on and no wood is passing through. When you start the feed, then the bearing should turn intermittently. Slow your feed rate if it is turning all the time.
In general, his set up was tighter all around than what I had interpreted from the owners manual and other sources. I can see how, over time (years), I may have to replace a bearing occasionally, but at this point I don’t see any wear occurring, and the results is worth it.
SM
-- SM
View Loren's profile
180 posts in 134 days
124 days ago
I set the bearing so it spins only when stock is fed into the
blade. It’s sort of my opinion that the rear thrust bearing
keeps the blade teeth from going between the guide
blocks – which would either dull the teeth or chew up the
blocks.
On my big 20” Crescent I don’t sweat it too much. I run a
1” blade on that saw and there is a lot of stiffness front
to back in the blade itself. With thin stock the blade doesn’t
touch the bearing much because the deflections isn’t
enough to push the blade into the bearing.
With a smaller blade, 1/4” or less, the bearing serves a real
support purpose when sawing thick stock. Generally the
wider blades require less support at the back. If your saw
in a little funky you might play with the bearings and the
wheels to get your cut perpendicular to the table – not so
important for resawing but critical for joinery.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online business building
martin007
123 days ago
thanks for the tip guys. I was actually refering to the blade going back and forth when running. The play from most forward to most back is 1/32. So I can’t put the rear bearing as close without it touching the blade.
I beleive that play comes from the wheels but not sure, like I said, I checked it with 2 blades.
123 days ago
Well, in that case the amount of play that is acceptable
is a matter of the sort of work you want to do.
At the least you should look at the tires. If they
are lumpy they can be replaced or trimmed round.
The bottom tire is not hard to trim under power using
a lathe chisel. The top tire is tougher. You’ll have to
have somebody drive the tire by holding a rubber sanding
drum mounted on a hand-held power drill against it while
you trim it with the chisel.
Another way is to take the wheel off the saw and mount
it on a lathe bed. Put a sanding disc on the lathe headstock
and with a bit of fiddling you can sand the tire to round.
Guide blocks should be set pretty darn close to the blade…
just enough that the blade slides through without dragging
against the blocks. Some people fold a dollar bill around the
blade and set the blocks up against the folded bill. I usually
just eyeball it and try to get it as close as possible without
“drag”.
Dick, & Barb Cain
5076 posts in 785 days
123 days ago
Fine woodworking has this great article on band saws in their latest issue.
Bookmark And Share This Page
