After a many hours of work great craigslist find
Forum topic by mark4345 posted 03-20-2012 01:12 AM 2845 views 0 times favorited 17 replies Add to Favorites Watch
View mark4345's profile
mark4345
71 posts in 2327 days
03-20-2012 01:12 AM
In my search for a tablesaw upgrade and months of reading reviews on this site, as well as others and weighing the options between a European sliding saw and the standard cabinet saw i was pretty well set on a slider. I all being very expensive i decided on the Hammer k3 winner a more economical option at $5400 to my door (if that can really be considered economical). I decided to sit on it a bit and think it over all the while searching the usually places for anything that may pop up.
So i see a listing for this Martin sliding saw from the late 1970s he was asking $1500. I had to go and check it out. I get there and see it is in rough shape…i couldnt start it because it was no longer hooked up to power…but he assured me it ran, i could not set a bevel past about 20 degrees because the motor bottomed out on the about foot and a half of sawdust in the bottom of the machine, the crosscut fence for the table extension was cracked bent and broken, and it took a great effort to move the slider because of all the dust caked all over and in the bearings.
I ask the guy what he has to get for it. His response is well one of the guys in the shop can scrap it for $500, so i have to get $600 can you do that? I already knew these go for much more than $600 in good working order, so what the heck for $600 even if this turns out to be complete garbage i can get my money back in scrap and in the motor which is a new 3 phase 7.5 hp which was replaced not that long ago.
So i rent a box truck with a liftgate, bring my strongest friend along and we load this 2000 lb beast into the truck and away we go. I get it home and takes 2 hours to get it out of the truck into the garage positioned where it currently sits (probably to never move again, this is HEAVY!)
Then let the work begin, more research on the site here about 3 phase motors and how to make them work on single phase power. I concluded my best option was to go with a phase converter, knowing the motor will only run at 75% capacity at 7.5 hp i didnt think that was a problem. While waiting on the converter and magnetic switch to make it run i began the cleaning greasing and lubing….then more cleaning and just when i thought i had all the sawdust out….more cleaning. The dust in the main body of the saw had been sitting in there so long the layers on bottom were starting to decay and turn into dirt. Got that all shoveled out, the motor removed, the slider all taken apart, bearing out…regreased and all put back together.
Switch and converter came in…got that hooked up and the saw worked. It cut like crap but it worked. Next came one of a couple trips to rockler for parts to remake the crosscut fence, miter slot, and get the various bits and pieces i felt i needed. a trip to the non-orange one for a sheet of melamine for the fences and extension tables and i was about in business.
After about 3 weeks of fooling with this it cuts perfectly! Exactly square..everything is parallel and perpendicular to the blade where it should be. Then the final step was adding a new forrest woodworker 2 blade. I bought one for general cutting and a plywood/thin veneer blade.
All told i spent right about $1500 including the truck rental to get it to my house. Great deal for a now excellent 8 foot european sliding tablesaw. I couldn’t be happier with it….well maybe with a new coat of paint but thats a whole new project.
17 replies so far
116902 posts in 3481 days
#1 posted 03-20-2012 01:18 AM
seems like a great deal, boy that’s a lot of saw.
View cabmaker's profile
cabmaker
1694 posts in 2713 days
#2 posted 03-20-2012 01:48 AM
No kidding thats a deal for sure !
View waho6o9's profile
waho6o9
8099 posts in 2481 days
#3 posted 03-20-2012 03:05 AM
Congratulations mark4345!
That saw is going to last you a long time.
View ShaneA's profile
ShaneA
6889 posts in 2502 days
#4 posted 03-20-2012 03:12 AM
Whoa! it is a beast. Congrats on the awesome score
View Vrtigo1's profile
Vrtigo1
434 posts in 2895 days
#5 posted 03-20-2012 03:12 AM
Man, sorry it didn’t work out for you. You must be totally bummed about not being able to spend $5k now! Just kidding, that is one heck of a craigslist find and it sounds like you had some fun fixing it up. Sometimes the tools you invest your time in end up giving you more satisfaction than the ones you buy at the store. I hope you get a lot of good use out of it!
View Loren's profile
9941 posts in 3552 days
#6 posted 03-20-2012 03:13 AM
It’ll spoil you for sure. Lovely old saw.
View wee3's profile
wee3
76 posts in 2176 days
#7 posted 03-20-2012 05:21 AM
Now thats a saw,good find,and good luck with it.
-- BiLL @wee3
View 559dustdesigns's profile
559dustdesigns
633 posts in 3072 days
#8 posted 03-20-2012 05:28 AM
Wow what a score.
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
View KMT's profile
KMT
603 posts in 2566 days
#9 posted 03-20-2012 06:38 AM
I love hearing stories like this. It sounds like this saw has gone to a good home. Enjoy
-- - Martin
mark4345
#10 posted 03-21-2012 01:45 AM
The more stuff i cut with this saw the more i like it. I am currently working on building a workbench with lots of storage cabinets and drawers. It really makes cutting down full sheets of plywood a breeze, both rip as well as crosscut.
View lieutenantdan's profile
lieutenantdan
176 posts in 2210 days
#11 posted 03-21-2012 02:56 AM
I think you may have just moved to the top of the tree huggers wanted list.
-- "Of all the things I have lost in life, I miss my mind the most."
View RandyM68's profile
RandyM68
693 posts in 2222 days
#12 posted 03-21-2012 05:13 AM
Nice saw, I wish I had room for one. I love used tools.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View AJswoodshop's profile
AJswoodshop
1057 posts in 2180 days
#13 posted 08-13-2012 11:21 PM
That’s a monster saw! That’s a cool sled man.
AJ
View Mainiac Matt 's profile
Mainiac Matt
7639 posts in 2232 days
#14 posted 08-14-2012 01:20 PM
great find… congrats…
-- Pine is fine, but Oak's no joke!
View Doss's profile
Doss
779 posts in 2168 days
#15 posted 08-14-2012 04:24 PM
Wow! That’s a big boy saw.
Good find and good luck with it. Looks like you’ll have a hard time outgrowing that thing.
-- "Well, at least we can still use it as firewood... maybe." - Doss
