would this drill bushing work good for bench dog holes or go with router?
Forum topic by TDog77 posted 03-20-2012 12:15 AM 1887 views 0 times favorited 4 replies Add to Favorites Watch
View TDog77's profile
TDog77
125 posts in 2322 days
03-20-2012 12:15 AM
Racking my brain here trying to find a good fix to drill my bench dog holes on my expensive maple top and I know there was a suggestion for this type of system on here and I wanted to see if this is the general idea? I was assuming you would place the bushing in some stock with the 1 inch hole bored from a drill press and press the bushing in and voila.
http://www.grainger.com/Grainger/Drill-Bushing-11P065
I would also like to know if you think it would be a better idea all together to just make as deep a cut as possible with a plunge router sporting a 3/4 upcut.
TDog77
#1 posted 03-20-2012 12:36 AM
Actually now I am thinking a piece of 2-3 inch hard stock with a plumb hole jig as a guide and a 3/4 standard bit might just be the best option.
View Fuzzy's profile
Fuzzy
298 posts in 3958 days
#2 posted 03-20-2012 01:03 AM
That bushing would work, but it would be faster & easier to just use a 3/4” pipe nipple either screwed into a flange or welded to a piece of scrap slat stock.
To locate your holes, sharpen one end of a 3/4” dowel … punch the mark with an awl … set the point of the dowel in the prick mark … slide the jig over the dowel & clamp it in place … remove dowel … drill hole.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View MrRon's profile
MrRon
4722 posts in 3213 days
#3 posted 03-20-2012 09:16 PM
Do you have a drill press so you can drill a plumb hole? If you do, use a forstener bit.
View TechRedneck's profile
TechRedneck
768 posts in 2826 days
#4 posted 04-04-2012 12:57 AM
Believe it or not, I found that the “old school” bit and brace did the trick for me, a good sharp bit and a block clamped below to prevent tearout works quick and clean. Why mess with power tools?
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
