Dang, I hate corian. Used to be an installer. Put in mucho thousands of dollars worth of the crap. But, it works for some people.
Kyle probably gave you everything. Just remember….it’s just plastic and epoxy glue. It’s not magic. Make sure you get a nice ooze. There are voids in the back surface and sometimes in the interior…and what you don’t figure out right away is that when you go to route those voids, if not filled, show up.
Also, the beauty of using spring clamps is that as the glue squeezes out the spring clamps continue to squeeze things together. We used to use buckets full…maybe one every 3”- 4”.
Any major profile needs power. We always used PC 3 1/4 hp routers. But multi-passes can work. Dang I HATE the smell of that stuff.
We also used plywood hot melt-glued to the back as filler strips.
Also it’s fun to put in the oven and bend into neat shapes.
-- arborial reconfiguration specialist
