Dealing With Early/Late Wood
Forum topic by gfadvm posted 428 days ago 606 views 0 times favorited 5 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
6611 posts in 856 days
428 days ago
Topic tags/keywords: sanding question
In woods where there is a marked difference in density between early and late growth wood, how do you get the piece sanded flat? It seems like the softer early wood always gets scalloped into valleys leaving late growth hills. This is less an issue with the drum sander and a big problem with the ROS.
5 replies so far
12048 posts in 1507 days
#1 posted 428 days ago
that is the problem with grainy wood sometimes
what i do is run it through the drum sander
and without changing the setting
run it through again the opposite way
over and over till it quits sanding at all
this takes care of any un-paralell between the drum head
and the moving feed tray too
i have found the problem
is the woods also dry at different rates over time
i have learned to build them and let them sit for a month or two
(after sanding coarse)
so then when i sand them they hopefully are settled
before i got them out as soon as possible
then had to take them back later and sand them again
(through the finish and refinish)
this box is where i learned this
it was flat when i made it
but months later it was all ruddy with ripples
in the different woods
even woods that are ‘dry’ can still be somewhat moist inside
when you split or machine them
so they can still move around some
View robert triplett's profile
robert triplett
1303 posts in 1270 days
#2 posted 428 days ago
This is one reason I stay away from soft woods or learn to like the ripple effect. I still use redwood sometimes and have this issue. As David said, a drum sander on the same setting a few times is a good solution.
-- Robert, so much inspiration here, and so little time!
View Clint Searl's profile
Clint Searl
845 posts in 527 days
#3 posted 427 days ago
Sometimes, the difference can be used to interesting effect. I sand blasted this 8×18 piece of cypress to emphasize the grain, tactilely and visually. It’s going to be the lid of a box.
-- Clint Searl.............We deserve what we tolerate
gfadvm
#4 posted 427 days ago
Thanks guys. Sounds like I should stick with the drum sander and don’t sand it with the ROS? I use the ROS to get rid of the linear sanding marks left by the drum sander. David. That is a way cool box! Robert, The redwood box I posted recently spawned this question. That’s why I’m not a big fan of softwoods either but the curly grain needed to be a box!
View Bernie's profile
Bernie
381 posts in 1003 days
#5 posted 424 days ago
Drum sanders might be the perfect solution to your problem if you have one, but I don’t own that tool. The only drum sander I’m familiar with is a $10,000 machine owned by a professional cabinet maker which is one GREAT machine. I’m sure there are more reasonable priced machines, but my 24 X 24 shop wouldn’t have room for that.
So, I would solve this problem with a cabinet scraper. I used to use sanders to try smoothing out the differences of wood joints until I worked for the cabinet maker I mentioned. He introduced me to cabinet scrapers which can shave off woods by skin depths. The only problem with cabinet scrapers is that you need to learn to sharpen them. My cabinet scrapers have elevated my work from OK to pretty good.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
