Random-Orbit Palm sander is posessed!
Forum topic by Tokolosi posted 433 days ago 980 views 0 times favorited 11 replies Add to Favorites Watch
View Tokolosi's profile
Tokolosi
616 posts in 526 days
433 days ago
Topic tags/keywords: sander orbital sander
I have a little 5” Black & Decker random orbit palm sander. It was fairly inexpensive and it has worked really well. However, last few times I used it it is acting super strange. I hope I can explain this; It spins, motor sounds good, gets up to speed adequately but it ‘bites’ into the wood if I apply any kind of pressure. I have to hold it just barely touching the wood. And of course that leaves gouges etc. If I apply pressure it either bites into the wood and bucks or it stops spinning braking the motor. And this is for any grit of paper I use and I tried different woods of varying hardness. The best analogy is like a car with clutch issues.
Does anyone know what may be wrong?
I have opened it and cleaned out all the dust and, with my untrained eye, could not see anything that looked wrong or broken.
-- “There is nothing like looking, if you want to find something. You certainly usually find something, if you look, but it is not always quite the something you were after.” ~ JRR Tolkien
11 replies so far
View chrisstef's profile (online now)
chrisstef
5294 posts in 1177 days
#1 posted 433 days ago
sounds kinda strange …. maybe try a piece of used up sandpaper on it and see if its still “biting” that may eliminate a couple of possibillities.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View JNP's profile
JNP
103 posts in 748 days
#2 posted 433 days ago
My dewalt did something similar…there is a small plastic “brake” that sits below the pad that needs replacing. It is super cheap plastic disc that controls the pad movement. If you have a repair center nearby pick one up or maybe find it online. My part is #26 in this photo. http://www.ereplacementparts.com/dewalt-dw422-type-evs-random-orbit-palm-sander-parts-c-100927422757.html
-- Jeff
Tokolosi
#3 posted 433 days ago
@ Christef: I have tried that with a 320 grit disk that is smoother than a piece of copy paper. Same results.
@ JNP: I will definitely look into that right now. Of course according to a quick online check that part on mine has been discontinued. But they still sell these things at Home Depot. So that doesnt make sense. I’m getting on the phone right now.
Thanks for the input gentleman. I really appreciate it.
Tokolosi
#4 posted 433 days ago
Update. Just got of the phone with a repair center. The part is no longer made. However, he said that the De Walt part may fit as the machines are clones. Go figure. Well Im off to grab one and see if it works.
View Sorethumbs's profile
Sorethumbs
38 posts in 818 days
#5 posted 430 days ago
count me as one with the same problem, the Dewalt.
Tokolosi
#6 posted 429 days ago
Update: While the DeWalt part was virtually identical to the one on my sander it was too small. I have the $2 part on order and hopefully will get it in a week. I hope it works. Had to loan a sander in the interim and I hate loaning tools. Something always go wrong and while I love buying new tools I hate doing so to replace on a loaner that gave the ghost on my watch.
Tokolosi
#7 posted 412 days ago
Finally got the little plastic ring for my sander. Installed it and had high hopes. But alas it still spins like a disk grinder. It did not fix my problem. But all is not lost. I have since found use for a small hand held ‘belt sander’!
View Grandpa's profile
Grandpa
2381 posts in 846 days
#8 posted 412 days ago
I had a sander do something like that once. It was a PC 505 pad sander. it would dart around and I was simply not big enough or strong enough to stop it from having a mind of its own. I finally resorted to the owners manual and it described my problem. the felt pad on that sander was not flat and it need to be cleaned up. I put a piece of sandpaper on a flat table (full sheet) and set the felt on the paper and started the sander. with the sander running I would pull it toward my body and it remove a bit of the felt pad. After a couple of times across the sanding sheet I put new paper on it and it worked like new. Maybe something like that??
View wee3's profile
wee3
76 posts in 443 days
#9 posted 412 days ago
Yea,plastic ring brake,sounds like.good luck.
-- BiLL @wee3
View ChrisFranklin's profile
ChrisFranklin
23 posts in 360 days
#10 posted 360 days ago
Bit of an old thread, but in hopes of helping somebody down the line: these sanders have 3 ball bearings. Two are for the two ends of the motor shaft like any other motor. The third is between the flywheel/fan and the sanding pad, and is slightly off-center, hence the random orbit. If this bearing seizes the RO sander becomes a high-speed direct-drive grinder. Sounds like this might be the problem in the OP. It’s part #23 in the drawing linked above, 4-5 bucks to replace.
-- Mud thrown is ground lost.
Tokolosi
#11 posted 359 days ago
Chris,
Thanks for the advice. I’m definitely going to give replacing that bearing a go.
