Recomendations on joining bookmatched wood for a box top and base
Forum topic by Blackfly posted 03-16-2012 03:24 PM 1366 views 0 times favorited 4 replies Add to Favorites Watch
View Blackfly's profile
Blackfly
13 posts in 2216 days
03-16-2012 03:24 PM
Hey guys I resawed some purpleheart to arpox 9/16 which I’m looking to join widthwise for some bookmatched sets for a top and bottom of a box. Which joinery process would you recommend, biscuit joints, dowels, or routering with a “lock miter router bit” or tongue and groove router bit? The box will be aprox 15” x 15” and the boards that I want to join have a slight warp from resawing but it is straitening out a bit more day by day. I am planning on doing an inlay in the middle right where the seem would be, would this be an issue?
Thx for any help
Jimmy
View Bill White's profile
Bill White
4853 posts in 3862 days
#1 posted 03-16-2012 04:18 PM
I gotta ask? Whassa matter with a good glue joint only? Tongue and groove would be my second choice.
Bill
-- bill@magraphics.us
Blackfly
#2 posted 03-16-2012 07:27 PM
Bill, so you would say just to clamp the two together with some glue? The top will be hinged to open and I wasn’t thinking that it would hold up for durability. That would def be the easiest, what is the best glue for the job? Yes I’m a newb : )
thx
Jimmy
View chrisstef's profile
chrisstef
17162 posts in 2908 days
#3 posted 03-16-2012 07:37 PM
Glue will due. Titebond 2 or 3 will be just fine. When you do glue them together clamp the piece to your bench or a table to keep it flat. My cheapo clamps like to put uneven pressure and will make a sweet dish out of a glue up if i dont use cauls to keep it flat. Most people believe that the glue is stronger than the wood itself.
Welcome to the gang blackfly.
View robert triplett's profile
robert triplett
1566 posts in 3007 days
#4 posted 03-16-2012 11:04 PM
Welcome. As far as I know, glue should be fine for that thickness of joint. It’s what I would do. I would also clamp flat on wax paper on plastic on my bench.
-- Robert, so much inspiration here, and now time to work!!!
