Ideal height for tablesaw/router table
Forum topic by jaydubya posted 03-16-2012 04:27 AM 12384 views 0 times favorited 7 replies Add to Favorites Watch
View jaydubya's profile
jaydubya
183 posts in 2780 days
03-16-2012 04:27 AM
Im making an all in one mobile workstation for my craftsman tablesaw with 52 inch T-square fence and router table in the right side extension. I want my table saw to be higher than it is since im 6’2” and it feels a little low for my comfort. Is there a rule of thumb for the ideal height? I have to get it right or live with it on the first try here. Does 4 inches higher sound reasonable, or too high?
7 replies so far
View David Grimes's profile
David Grimes
2078 posts in 2608 days
#1 posted 03-16-2012 05:04 AM
I am 6’2 also. I like (and have) the 42” to 45” range throughout my shop versus the 37” TS standard height. So yeah, 4 inches is reasonable IMO… or even 5” – 7” higher. Better on the back, better visual, etc.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2740 days
#2 posted 03-16-2012 05:49 AM
Hi Jay,
I used a lot of step stools to help figure out what a good distance was, for me it was about an inch above my belt. Having the saw at a proper height has made a world of difference for me.
What type of craftsman saw do you have? is it a fully enclosed base? or the hybrid style? or the contractor saw.
“Getting it right or living with it” really sucks, I would design your cabinet to be more flexible, what I did was designed it a little more modular. Here is a picture of my saw when I first put it together.
I was originally concerned the saw was going to be too low, so I didn’t even screw the box down yet, the weight was sufficient to keep it from moving much if I was careful. I worked with it for a week before I decided I liked this height and screwed the saw box down.
If the saw was too low I could have just inserted extra plywood or MDF sheets to the bottom under the box raise it up.
Once you get the final height decided on you can work on the drawer boxes and cabinets you want to add to the right side.
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
jaydubya
#3 posted 03-16-2012 01:44 PM
Jeremy, I have a 21833 “hybrid”. the mobile base that came with the saw is pretty good, until i added the 52 inch sawstop fence. Ill be building something almost exactly like you have pictured for my saw, and adding a router table at the far right
View canadianchips's profile
canadianchips
2600 posts in 2965 days
#4 posted 03-16-2012 02:39 PM
You may think higher right now, when you start to use it more maybe a little lower would have been better.You can always add spacers to raise it higher later. Do you want to cut the station apart if you made it too high !
Will you be the ony one using this saw ?
I have worked on benches that were higher, I was always afraid of getting hit in the head rather than
the “berries”!
Kitchen cabinets ,bathroom vanities all have a standard height…for reason. comfort for the average person.
Pick a height that you want !
jaydubya
#5 posted 03-16-2012 07:03 PM
canadianchips, thanks for pointing out the standard height for cabinets. We dont have a dishwasher, and have to do the dishes by hand. The kitchen counter/sink, although “standard” height, is much lower than is comfortable for me. I think 4-5 inches is the magic number. Im not your “Average” guy, im 6’2” with lower back issues
View longgone's profile
longgone
5688 posts in 3277 days
#6 posted 03-16-2012 07:46 PM
I have a grizzly cabinet saw that is standard height plus about and extra inch+ added due to the mobile base. I am 6ft and I feel that it would better suit me if it were about 4” taller. The correct height for anyone is what works for your personal height…whether someone is 6’8” or a midget will determine what is best.
I will not rebuild mine again to be taller until I buy a new saw…cause I also have a cabinet matching the saw height to the right of the saw in addition to an outfeed table/worktable..These wouls all have to be increased in height.
View RandyM68's profile
RandyM68
693 posts in 2286 days
#7 posted 03-16-2012 11:23 PM
I’m not a midget, I’m almost as tall as you guys when I wear my heels. With my shop shoes on, I’m more comfortable with a twenty eight inch work surface. Just make it fit you. Forget about these other guys.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
