Router Plate Insert
Forum topic by Rookie702 posted 03-15-2012 08:13 PM 1904 views 0 times favorited 7 replies Add to Favorites Watch
View Rookie702's profile
Rookie702
43 posts in 2271 days
03-15-2012 08:13 PM
Ok, I give up….
I have looked online at router table extension that have been added to table saws, and it seems like everyone i see the hole where the router plate sits it always routered out perfect. How in the heck is this accomplished. Every time i attempt to create a perfect fit, I fail. I mean i do know how to take a measurement.
7 replies so far
View Paul M Cohen's profile
Paul M Cohen
86 posts in 3772 days
#1 posted 03-15-2012 11:44 PM
The way I did it was to use the plate as a template for a router bearing bit. I then routed a pattern in plywood, I used this pattern with a bearing bit to cut the shelf the plate sits on, then I used the side of the shelf to guide another bearing bit to cut the exact hole to fit the plate. I used multiple router bits with a varity of top and bottom bearings and different sized bearings. You can also buy the templates. I have avoiding speciffing top and bottom for the bearings because I am not sure the correct names.
-- Paul, Beaverton OR, www.TravelbyPaul.com
View Scot's profile
Scot
344 posts in 3390 days
#2 posted 03-16-2012 12:40 AM
Most of the quality router plates have a template for them, which is usually sold separately. I used to make my own but have found buying them isn’t really that expensive when you figure in time and materials.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View NiteWalker's profile
NiteWalker
2737 posts in 2571 days
#3 posted 03-16-2012 06:28 AM
I bought my template as well.
I paid $15 shipped, which is worth the time/effort I would have spent making one.
View nwbusa's profile
nwbusa
1021 posts in 2280 days
#4 posted 03-16-2012 08:59 AM
Template is probably the best way to go. I did without and used a parallel fence on my plunge base router. Got a perfect result but I was very careful (I.e. slow).
-- John, BC, Canada
View HalDougherty's profile
HalDougherty
1820 posts in 3231 days
#5 posted 03-16-2012 11:40 AM
I used a much cheaper and simpler solution. I placed the router plate on a top made from two MDF 3/4” laminated boards and drew a line around the plate. Then I made another line inside the outer lines to leave a shelf for the plate to sit on. I don’t remember if it was 3/8” or 1/2”??? I measured my rabbit bit to see what the depth would be after the rabbit was cut. Then I drilled a hole and used my jig saw to cut out the opening leaving enough waste to clean up with a router bit. Then I clamped some 3/4” boards around the opening and used a pattern bit to smooth the edges and bring them to the final shape. Then I used the rabbit bit to make the shelf the router plate sits on. I put an adjustment screw in each of the 4 corners of the table top so I could adjust the plate to exactly fit the top.
-- Hal, Tennessee http://www.first285.com
View Chipy's profile
Chipy
374 posts in 2587 days
#6 posted 03-16-2012 05:53 PM
MLCS inc. router plate template.
View crashn's profile
crashn
528 posts in 2459 days
#7 posted 03-16-2012 08:04 PM
purchased template here as well
-- Crashn - the only thing I make more of than sawdust is mistakes
