Templates - what to use?
Forum topic by Zuki posted 126 days ago 182 views 0 times favorited 13 replies Add to Favorites
View Zuki's profile
Zuki
855 posts in 564 days
126 days ago
Topic tags/keywords: template hardboard
I Have been reading some wwing articles where they use templates for the layouts of cuts. They mostly use thin plywood or hardboard.
What the heck is hardboard? In the pics it looks like heavy duty cardboard, but what is it? Does it have any other names?
What do others use to make templates?
View WayneC's profile
WayneC
5685 posts in 584 days
126 days ago
You should be able to find hardboard at Home Depot if you have one near by. They sell it in 1/4 and full sheets where I live. Normally 1/4 inch thick.
9116 posts in 309 days
126 days ago
It should be in the same area where the pegboard is sold.
As far as templates go I also use 1/2 inch mdf since it is fairly cheap.
WayneC
126 days ago
I prefer MDF as well. More room for the bearing to ride.
View CelticDreamer's profile
CelticDreamer
27 posts in 141 days
126 days ago
The Home Depot near me has two different thicknesses of hardboard (I think they are 3/16 and 1/4), but I agree with Scott and Wayne – 1/2 inch MDF is fairly cheap and more versatile.
-- last night I played a blank tape at full volume - the mime next door went nuts!
View Russel's profile
Russel
1230 posts in 426 days
126 days ago
I used to use 1/4 plywood, but I’ve started using 1/2 MDF which is a lot sturdier and easier to work with.
teenagewoodworker
2034 posts in 255 days
126 days ago
i perfer 1/2” MDF but hardboard is i think like a beefed-up cardboard. its what pegboards are made out of but they paint it or put something else on it to make it look pretty. i can usually get it in both 1/4” and 1/8”
View Jeff_T's profile
Jeff_T
31 posts in 159 days
126 days ago
You are much better using MDF (Medium Density Fibre board over plywood, no warp, great for future storage, does not splinter, and can be painted. MDF will be around for a long time should you wish to duplicate your project, just mark the templates you have made and duplication is a snap.
Use 1/4 or 3/8 MDF and you will save a bundle. Many store sell it in 2×4 sheets making handling easier.
Good Luck
-- Jeff T in Westport CT.
View bhack's profile
bhack
118 posts in 207 days
126 days ago
Hard board is also referred to as tempered board, I think.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
View GaryK's profile
GaryK
8489 posts in 475 days
126 days ago
Hardboard is made from compressed wood fibers. It always has one side Tempered and sometimes both.
It’s tempered by soaking the side to be tempered in Linseed oil and applying pressure and heat.
The tempered side is nice and hard and smooth.
I use it all the time.
Any home center will have it. It’s dark brown.
View John Gray's profile
John Gray
698 posts in 372 days
126 days ago
Hardboard =’s Masonite where I live the same stuff as pegboard but no holes.
View Jarrod Zion Murphree's profile
217 posts in 210 days
126 days ago
I prefer 1/8” or 1/4” MDF for templates that won’t be used again, or will be used infrequently. 1/2” or 3/4” MDF or Baltic Birch for patterns and templates that I will use often. I like the Baltic birch because it is at least as dimensionally stable as MDF, but won’t wear in the areas where bearings, etc.. contact it as quickly/easily as MDF. It is ‘spensif though…
I only use hardboard in a pinch if I have nothing else available. It is usually dark, and you can’t see pencil lines/markings as well, and it smells funky – like chocolate flavored coffee or something – when you cut it. I don’t want anything to smell like that except chocolate flavored coffee …
Regards, JM
-- Jarrod, Eagle Nest, NM http://anthologyfinefurniture.wordpress.com
View jcees's profile
jcees
465 posts in 286 days
126 days ago
I use both hardboard and MDF in the 1/4” thickness. WARNING: they both turn to crap with a little water. So keep ‘em dry and they’ll last a great long while. A coating of some sort works too. I specifically use the prefinished hardboard to make story poles, templates and jigs. It’s a nice semi-gloss white. Great stuff but wear a good mask as the dust is nasty when either cutting or sanding.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View tresselk's profile
tresselk
8 posts in 256 days
126 days ago
I have found that MDF is incredibly easy to sand and refine to make a perfect template.
Bookmark And Share This Page
