cheap router raiser for router table
Forum topic by jockmike2 posted 04-26-2007 02:56 PM 3982 views 0 times favorited 9 replies Add to Favorites Watch
View jockmike2's profile
10635 posts in 4214 days
04-26-2007 02:56 PM
Topic tags/keywords: router raiser scissor jack cheap
If you’re not rich like I am, I can’t afford the top of the line router table with an adjustment for your router built in. An old scissor jack works great. I have a shelf below my boughten router table, Home Depot 100.00 Wolfcraft that I installed myself. I set the scissor jack under the router and with the plunge router unlocked, I can adjust the router up and down as needed and precisely where I want it with a twist of the altered jack handle. Easy and cheap. Jockmike
9 replies so far
35111 posts in 4368 days
#1 posted 04-26-2007 02:59 PM
Very interesting Mike.
#2 posted 04-26-2007 03:01 PM
I’ve used this for about 3yrs. now, with 2 different plunge routers without a bit of trouble. mike
View woodspar's profile
woodspar
710 posts in 4067 days
#3 posted 04-26-2007 03:45 PM
Mike, I have a plunge router and a scissor jack. How do you “interface” the metal jack “head” and the top of the router? Did you use a block of wood, metal, plastic? Did you build a special jig? Is there a picture available?
-- John
View niki's profile
niki
426 posts in 4047 days
#4 posted 04-26-2007 04:08 PM
Very good idea Mike
I cannot use it because my router table is “crazy” but with your permission, some small advice;
When you “call it a day”, leave the jack in place and lift the router, say, some 3/8” with the plunge lock released.
It will prevent the sagging of the router insert plate or the table top (due to the router weight), I do it already 8 years, no sagging at all.
niki
#5 posted 04-26-2007 04:29 PM
No Niki I don’t do anything as far as letting off the pressure, but probably should. I do have two other plunge routers so it is dedicated to the router table. Woodspar, because of the air vents in the top of the router I use a wooden plate with four dowels screwed to it to leave a small vent crack for the router. I put some rubber on the tips of the dowels to not mar the router. You could use carpeting or anything to not leave marks on your router. Like I said I’ve used this set up for 3 yrs with no problems with 2 different routers. Nothing happened to the first router I just put in a 3 hp router in place of my first 2 hp. Hope that helps. Any other questions feel free to ask. It works great.Mike
Dick, & Barb Cain
8693 posts in 4267 days
#6 posted 04-27-2007 01:19 PM
Sounds good Mike. could you show a picture?
#7 posted 04-27-2007 06:32 PM
I’ll try Dick, I’ve been trying to upload my pictures into photobuckets all at once and just ain’t having ahy luck. Like I said I’ll give it a shot indiviually. mike
View Hawgnutz's profile
Hawgnutz
526 posts in 4044 days
#8 posted 04-27-2007 06:41 PM
I am looking forward to seeing your “lift” Mike. I just got a new router table and this sounds just like what I could use!
God Bless,
Hawg
-- Saving barnwood from the scrapyards
View oscorner's profile
oscorner
4563 posts in 4278 days
#9 posted 04-27-2007 09:40 PM
Mike have you been sneeking around my shop. I thought I had dibs on using a sissor jack to raise and lower my router. I guess true buddies think alike. ;^)
Woodspar, I use a block of wood to keep the metal jack head from damaging the router.
I usually take my router out of the table when finished and put it and the jack away.
-- Jesus is Lord!
