Jet Pro Saw Rails - Out of Square
Forum topic by Rookie702 posted 03-14-2012 06:09 PM 807 views 0 times favorited 4 replies Add to Favorites Watch
View Rookie702's profile
Rookie702
43 posts in 2272 days
03-14-2012 06:09 PM
Was wondering if anyone has had any issues with the front and back rails not being parallel to each other.
I am adding a router to the underside of of the right side extension, and when i initially cut my plywood for the table top, it didn’t fit. come to find out that from the right edge of the saw which measures exactly 27” in depth. If i take a measurement out at the far end of the rails i measure 27 5/8”...
I have taken the rear rail off and reattached but still no good.. my next step is going to take the front rail off and start all over.
anyone ran into this situation before,
View Bill White's profile
Bill White
4928 posts in 3955 days
#1 posted 03-14-2012 06:13 PM
I could see a small difference which could be shimmed, but 5/8” is a BUNCH. Sompin is way wrong.
Bill
-- bill@magraphics.us
View Sawkerf's profile
Sawkerf
1730 posts in 3063 days
#2 posted 03-14-2012 06:17 PM
Check the separation at 3-4 points across the full length of the rails. Sounds like something is bent or the rails aren’t correctly attached to the saw table.
Rookie702
#3 posted 03-14-2012 06:21 PM
Sawkerf,
Yes I believe i need to take the entire rails system down, and start fresh…The fence seems to operate ok… it does not bind or hang up…
Sawkerf
#4 posted 03-14-2012 10:07 PM
Can you clamp the fence down at its full right travel? If the rails are really 3/8” off, you probably cant’ clamp it down.
