Handplane advice
Forum topic by Dale Robinson posted 538 days ago 304 views 0 times favorited 11 replies Add to Favorites Watch
View Dale Robinson's profile
Dale Robinson
25 posts in 811 days
538 days ago
Topic tags/keywords: question
I went to a heritage festival today and talked to one of the guys doing woodworking with traditional tools I talked to him about a problem I was having making small joints that have a tight fit. He showed me a shooting board and told me how to use it.
He laid a board down on the shooting board and and ran a plane across the piece. When he was done, I noticed that he had actually planed the end grain of the board. I am using thin boards ( less that 1/2 inch thick ) and I have tried running end grain across my joiner with terrible results. Can the plane run across these thin boards without tearing them up?
Dale
View WayneC's profile (online now)
WayneC
6051 posts in 996 days
538 days ago
Absolutely.
LumberJock Alf has good info on her web site
http://www.cornishworkshop.co.uk/shootingboards.html
My current shooting board setup is in my blog. Plane is by Lumberjock Phil Edwards and the shooting board is by Michael Conners out of Australia.
http://lumberjocks.com/jocks/WayneC/blog/1987
WayneC
538 days ago
Oh and if your looking to make a shooting board from the plans in Alf’s sites, I would recommend a used Stanley Baily 5 1/2 as a good starter plane to use. If you want to spend a little more money then one of the low angle jack planes from LN or LV.
Lie-Nielson Low Angle Jack Plane
Veritas Low Angle Jack Plane
WayneC
538 days ago
Also depending on what your doing you can plane end grain with the right technique with a low angle block plane or a bench plane for that matter.
View EdC's profile
EdC
458 posts in 739 days
538 days ago
I love my shooting board, I have it set up to do 90’s and 45’s. I use my LN low angle jack or my LN Scew plane they both do a great job.
-- Ed - Milan, IN
teenagewoodworker
2482 posts in 666 days
538 days ago
ya its not a good idea to run end grain over a jointer but a shooting board would work great on end grain. thats the beauty of planes, they can be used for almost any task you can think of.
View johnjoiner's profile
johnjoiner
153 posts in 792 days
538 days ago
I use an old Bailey #7 with an after-market blade for my shooting. It’s a great thing to be able to fine tune the length of a piece 1/1000 of an inch at a time.
I played with both the LN and LV low angle jacks at the WW show a few months ago, and fell in love with the LN. But my #7 works well enough that I haven’t brought myself to spend the money yet.
-- johnjoiner
Dale Robinson
537 days ago
Wow, guys.
Thanks for all the information. It was all very useful.
Dale
View Keith Cruickshank's profile
Keith Cruickshank
41 posts in 543 days
537 days ago
Yes, as Wayne says, a low angle block plane is great for working end grain. If you don’t have a shooting board handy, the key in that case is to use a backer block or board to prevent tear-out on the back side where the blade edge exits the back side of the stock. The shooting board has one built-in so to speak, but you can get the same results in a pinch with a backer board simply mounted behind the stock place in a vice.
Good luck.
Keith
p.s. For some, this video demo might help – go to:
http://woodtreks.com/an-introduction-to-five-top-plane-types/20/
(go to minute 2 for block plane demo on end grain)
-- Keith Cruickshank, www.woodtreks.com - on-demand woodworking videos
WayneC
537 days ago
Cool video Keith. Who is the manufacture of the wooden smoother and jointer? HNT Gordon?
View John Ormsby's profile
John Ormsby
503 posts in 635 days
537 days ago
They look like Ulmia brand planes
-- Oldworld, Fair Oaks, Ca
View Dorje's profile
Dorje
1767 posts in 895 days
535 days ago
Dale – not much new to say here, but a shooting board is a must to fine tune the work you’re doing…especially good on that scale. It’s true that almost any well tuned plane can give you good results.
I use a LN 62 for my shooting, but have felt the LV and it really seems to have more heft (which may make it even a better plane for shooting). A friend of mine uses a 5 1/2 and that too has the heft needed. johnjoiner uses the #7. That fits the bill too! Size of the plane really depends on the work, though a larger plane can handle a much wider range of stock than a smaller one.
Good luck!
Here’s another couple LJ shooting board contributions…
http://lumberjocks.com/projects/3003
And Mot’s VIDEO:
http://lumberjocks.com/jocks/boboswin/blog/3407
