Bevel up on a #4 Stanley?
« back to Hand Tools forum
Forum topic by Truck11 posted 03-13-2012 05:07 PM 2326 views 0 times favorited 8 replies Add to Favorites Watch
View Truck11's profile
Truck11
7 posts in 2399 days
03-13-2012 05:07 PM
Topic tags/keywords: question tip
I needed a decent smoothing plane, but couldn’t afford the ECE Primus #711 or Veritas Low-angle smoother I want, so I took the (recently sharpened) blade out of my Lowes-bought, $20 #4 Stanley and flipped it upside down, thus making it a bevel-up plane. Adjusted the frog for a nice, tight mouth and left the chip-breaker in place, just on the reverse side of the blade.
So far, works pretty well.
Any thoughts? Suggestions? Am I ruining my plane (not that it really matters, since I will make a quality smoother purchase soon.)
Thanks
8 replies so far
View Brandon's profile
Brandon
4152 posts in 2980 days
#1 posted 03-13-2012 06:37 PM
This sounds like it’d be the equivalent of having a high-angled frog on your plane. Depending on the angle your bevel is on the iron, you’re essentially coming at the wood with a 60 to 60 degree iron. Haven’t tried it myself, but sounds interesting. Does the blade chatter? I doubt this would ruin the plane, but probably not operate as well as a true bevel up would.
-- "hold fast to that which is good"
View Kenny 's profile
Kenny
260 posts in 2477 days
#2 posted 03-13-2012 06:49 PM
The plane you speak of is not a Bailey type #4, but has the blade adjustment similar to the common Stanley spokeshave (sorry, model # slips my mind), correct?
I also don’t believe it has a chip-breaker (cap iron).
While you crtainly won’t hurt it, I think you would benefit greatly just by swapping to a good old Stanley #4 Bailey type plane. It’s a much better built plane in reality, and even in stock form will likely perform better than your upside-down blade plane.
Where as that plane you have doesn’t have the Bailey adjuster, but instead the knobs at the top of the blade, you may be able to fashion a small wedge from a solid hardwood to fit behind the blade to make a high-angle frog of sorts. I’m not sure if it would even work, just a thought.
If you’re happy with your plane how it is, use it.
If you aren’t doing huge panels, a standard angle #9-1/2 Stanley block plane with a 35 degree bevel will make a good high-angle smoother for smaller pieces. Works really well to be honest.
Good luck, and good job on the creativity! One of the best qualities a person can have is creativity and not being afraid to try new things, even if they’re not “normal”.
-- Kenny
View Don W's profile
Don W
18756 posts in 2596 days
#3 posted 03-13-2012 06:56 PM
I would think this would cause more of a scraping action than a planing action. Its not going to hurt, but it will change the cutting angle. It should work better for some task and not as well for others.
View Bill White's profile
Bill White
4950 posts in 3989 days
#4 posted 03-13-2012 07:16 PM
My #4 is bevel down, and can scare me with the shavings. Really a SMOOTHING plane.
If your plane works well for ya, don’t argue.
Bill
-- bill@magraphics.us
bandit571
20266 posts in 2712 days
#5 posted 03-13-2012 07:33 PM
I have that H-F #33. I run it both as a bevel up, and a bevel down. Blade is nice and thick as well. And, for about $9….......
Truck11
#6 posted 03-14-2012 06:43 PM
Actually it is a Stanley model #4. I know the model you’re talking about with the spokeshave-type adjustments, and yes, they do often sell that one at lowes (I actually have that model gathering dust on my pegboard because it has never worked well) but this is a bailey-type with a cap iron.
I have noticed far less (almost zero) chatter, especially when compared to its performance with the bevel down.
I’m using it as something between a scraping plane and a smoother, downhill grain on small boards. It’s working better than I expected. It’s not a Primus or a Veritas smoother, but it’ll do until…..
For larger work, I have a Woodriver #6 Fore plane that I am very happy with.
This is not my first frankentool, nor do I expect it to be my last. I was just shocked and surprised at how well it works – especially for such a simple fix.
Thanks for the kind words and feedback.
-a
View thebenchdogs's profile
thebenchdogs
9 posts in 2294 days
#7 posted 03-15-2012 01:01 PM
As long as it works, that is all that matters. Sometimes thinking “outside the box” creates some really good alternatives. Just like when it comes to sharpening. There are so many different ways to sharpening plane irons and chisels, and as long as the method you use works, that is all that matters. Good luck.
-- Scott
View PatPollin's profile
PatPollin
11 posts in 2310 days
#8 posted 03-19-2012 10:45 PM
The high cutting angle should give you an advantage getting clean shavings on difficult grain patterns thanks to the scraping effect the previous poster mentioned. This breaks the fibers closer to the blade edge instead of allowing them to tear up. The Lee valley catalog has a good diagram of this but I can’t find a link to it online.
