Marking Gauges
« back to Hand Tools forum
Forum topic by thebenchdogs posted 438 days ago 1191 views 0 times favorited 21 replies Add to Favorites Watch
View thebenchdogs's profile
thebenchdogs
9 posts in 438 days
438 days ago
Topic tags/keywords: plane
Anyone have any feedback on the Lee Valley Wheel Marking Gauge? I currently have a traditional pin Marking Gauge, and wanted to get some feedback on the wheel gauges.
Thanks
-- Scott
21 replies so far
View Brandon's profile
Brandon
3775 posts in 1124 days
#1 posted 438 days ago
I have the basic wheel marking gauge from Veritas/Lee Valley. I use it all the time. Personally, I hate the traditional style mortise gauges where you basically scrape a line. The wheel works great. If I need to replace it, I’d probably buy one with the micro-adjuster on it next time.
-- "hold fast to that which is good"
View crank49's profile
crank49
2291 posts in 1144 days
#2 posted 438 days ago
Wheels are good. Pins are . . . not so good.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Bill White's profile
Bill White
2609 posts in 2133 days
#3 posted 438 days ago
Just used my pin type this AM. Wheel would be a LOT better.
Bill
-- bill@magraphics.us
View Willeh's profile
Willeh
197 posts in 512 days
#4 posted 438 days ago
I have the ” Micro-Adjust Gauge, Imperial”
http://www.leevalley.com/en/wood/page.aspx?p=59455&cat=1,42936
Worth the extra few bucks. I love it.. very precice, cuts a nice smooth line… be careful tho, it rolls off the top of your worbench really easily (Cringe)
-- Will, Ontario Canada. "I can do fast, cheap and good, but you can only pick two... "
thebenchdogs
9 posts in 438 days
#5 posted 438 days ago
Any feedback on the knives used on the traditional mortise gauges? I saw a video on the Woodwhisper, and Marc was using a Mortise gauge with a knife, in place of the standard pin.
-- Scott
View jmos's profile
jmos
637 posts in 542 days
#6 posted 438 days ago
I found my pin style mortise gauge worked much better when I took a file to it and made it more knife-like.
I also have the LV wheel gauge and I really like it. It’s my go-to marking gauge for almost everything.
-- John
View tenontim's profile
tenontim
2129 posts in 1917 days
#7 posted 438 days ago
I’ve had one for quite a while and use it all the time. It makes a nice clean mark. I also filed a flat spot on the wheel, so it wouldn’t roll off the workbench (the only negative I’ve found).
-- Tim-- http://www.tmuli.com
View Julian's profile
Julian
278 posts in 863 days
#8 posted 438 days ago
I have a wheel gauge and use it all the time. Never tried a pin gauge and don’t have any reason to change. The wheel leaves a nice clean line.
-- Julian
View Kenny 's profile
Kenny
260 posts in 621 days
#9 posted 438 days ago
I have a home made marking gauge that uses a knife, and iw works great! Precise, cuts a nice smooth line, nice wide bearing surface, I can sharpen it easily, and best of all, it onlt cost me about $3 to make it.
As well, since I can adjust the knife to cut deeper than a wheel, I can use it to cut strips of veneer or other thin materials.
I’ll post a picture of it later so you can see how it’s made. It’s quite simple and I’m sure most anyone could copy it in a few hours at most.
I plan to make a better version soon and add a sliding dovetail for the head to ride on so it stays 100% square, though I have yet to have an issue with mine anyway. I just want to see if I can do better.
I have the $10 cheapie round wheel gauge from Rockler (on sale) and it does work well, bu it lacks the large bearing surface of my gauge. The one area I like it, is on the edge of boards when marking dovetails, as I can roll it over the edge.
I think my set up is pretty good. I have both and can use either where they work best, and I only have $13 invested.
BUT, those micro-adjust gauges are nice too. Not sure if it’s worth $50 nice, but nice nonetheless.
-- Kenny
Kenny
#10 posted 438 days ago
As a final thought, pin gauges suck IMHO. They’ll get you by, but they tear the fibers rather than cut it. Filing. Knife-edge on the pin helps, but it’s still too small of a blade to really track well.
I had bought a BORA low-end pin unit, and I gave it away when I made mine.
If you could make a traditional knife type with a micro adjust, you would what would be the ultimate marking gauge IMO.
Maybe I’ll run that by Incra, see what they come up with???
-- Kenny
View waho6o9's profile
waho6o9
2936 posts in 750 days
#11 posted 438 days ago
http://www.dilegnosupply.com/Marking-Measuring/gauges_japanese_marking_gauges.htm
Japanese marking gauges are better than the wheel marking gauges because they roll off the table, Oops.
I’m sure the Lee Valley is a good one. I bought a fox shop one and it wasn’t any good, the stupid keeps coming loose and rolls around. Too much hassle.
thebenchdogs
9 posts in 438 days
#12 posted 438 days ago
LV has a nice Mortise gauge with a knife, and in seeing only in a demonstration, it appears to work well. The one down side I heard with the wheel, is that there isn’t much fence to rid along the stock. Never owned a wheel gauge, I can’t comment, but like anything else, it is all trial and error.
-- Scott
View bondogaposis's profile
bondogaposis
1254 posts in 524 days
#13 posted 438 days ago
I like the LV wheel gauge a lot. It does have a tendency to roll and I have caught it a few times. I’m pretty sure I will be filing a flat spot on it soon.
-- Bondo Gaposis
Bill White
#14 posted 438 days ago
Well, mortising and marking gauges are two different animals. I use the traditional 2 pin gauge for mortices. I’m a luddite.
Bill
View Bertha's profile
Bertha
13115 posts in 866 days
#15 posted 438 days ago
I like the wheels much better than the pins. Much better. I think it’s worth the investment.
