flattening the sole of a plane
« back to Hand Tools forum
Forum topic by Zach posted 03-13-2012 04:00 AM 1579 views 0 times favorited 7 replies Add to Favorites Watch
View Zach 's profile
Zach
5 posts in 2231 days
03-13-2012 04:00 AM
I’m a beginning wood worker and I was wondering the process used to flatten a planes sole
-- Never laugh at live dragons, The Hobbit
7 replies so far
View Brandon's profile
Brandon
4152 posts in 2916 days
#1 posted 03-13-2012 04:04 AM
Welcome to Lumberjocks! I don’t flatten the sole of every plane—just the ones that really need it, like the shorter smoothing planes. When I do flatten it, I like to start with a long sanding belt, usually one I used already on a belt sander. I use spray adhesive to attach the sanding belt to a flat surface, then just run the plane over it repeatedly until the whole thing is flat. You can mark up the sole with a sharpie to see where metal is being removed and where it is not. I’m sure others will have some different suggestions, but this method has worked for me.
-- "hold fast to that which is good"
Zach
#2 posted 03-13-2012 04:21 AM
I’m worried about this spot. I spent a whole 30 bucks on this No 4. on ebay. I’m a total newbie to wood working and I’m leaning toward hand tools. I also have a 5 1/4 which I bought thinking it was a larger version of the no 5. (NOOB!) Its in good shape aside from an extermely dull blade.
Brandon
#3 posted 03-13-2012 04:28 AM
Smitty,
I would run that over some sandpaper a few times and if the plane is flat, the spot won’t affect its use. I have one block plane with some serious pitting in the sole, but it doesn’t really detract from the usability of the plane.
Regarding the 5 1/4—that’s a great plane. Hold one to it, but still you’ll want a regular No 5, which are plentiful on ebay.
View Farkled's profile
Farkled
28 posts in 2280 days
#4 posted 03-13-2012 09:12 AM
The larger the plane, the less you should wish to flatten it yourself. Can you guarantee that the substrate you use to flatten against is flat? Within .0005” ? If you can’t do that then flattening doesn’t matter. More to the point: use the plane. If it planes well, then no flattening is required. Move on with life. If it does not plane well, either have it professionally ground or go buy another plane.
IMO & YMMV
View Don W's profile
Don W
18685 posts in 2532 days
#5 posted 03-13-2012 01:16 PM
I use a piece of granite with a cut sanding belt glued to it.
I agree though it only needs to be flattened if its not working well. If its real bad, I’ll start on the belt sander. Get it close than move to the granite.
Smoothers are most important. The closer thay are the better they work. Jack planes do not matter much.
Don W
#6 posted 03-13-2012 01:17 PM
oh, and welcome to LJs
View Willeh's profile
Willeh
228 posts in 2304 days
#7 posted 03-13-2012 01:32 PM
Hey, Welcome to LJs!
Have a look at my Blog agoub restoring oild handplanes:
http://lumberjocks.com/Willeh/blog/27918
Part 3 discusses flattening and resurfacing the sole. Feel free to msg me with any questions!
-- Will, Ontario Canada. "I can do fast, cheap and good, but you can only pick two... "
