Cutting aluminum
Forum topic by quartrsawn posted 433 days ago 1138 views 0 times favorited 9 replies Add to Favorites Watch
View quartrsawn's profile
quartrsawn
110 posts in 1380 days
433 days ago
Topic tags/keywords: question miter saw blade milling aluminum cutting
I need to trim an aluminum threshhold/saddle. Can this be done safely on a 10 in. miter saw with a 60 tooth carbide blade? It is 5” wide x 3/32 thick. Thanx
-- Nat - West Sayville,L.I., NY
9 replies so far
View oluf's profile
oluf
252 posts in 1206 days
#1 posted 433 days ago
Yes. Just ware a face mask. The chips are hot and they are sharp.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View GerryB's profile
GerryB
32 posts in 749 days
#2 posted 433 days ago
How about a hacksaaw?
-- The pursuit of excellence is gratifying and healthy. The pursuit of perfection is frustrating, neurotic, and a terrible waste of time. Edwin Bliss
View Viktor's profile
Viktor
467 posts in 1585 days
#3 posted 433 days ago
Yes. I cut aluminum extrusions and angles. Normally you would need a specialty blade with different teeth angle, but for smaller peaces regular 60-t blade will do. Spray some DW40 on it for cooling and lubrication, although for a piece this small it does not matter much. Clamp well. And yes, chips get hot.
View BlankMan's profile
BlankMan
1487 posts in 1520 days
#4 posted 433 days ago
I’ve got a couple of 10” blades made especially for aluminum. They’re HHS not carbide and have way more teeth, I’d guess at least 80 maybe more, and a very shallow gullet. They weren’t expensive either, don’t remember what I paid but I wouldn’t have bought them if the were. Picked them up at Menards and I think they were Oldham. Don’t know if they carry them anymore or if they’re even made anymore. Someone told me a trick one time when cutting aluminum and that was to put the blade on backwards. Sounds stupid and I’m not suggesting or endorsing it but I have done it when cutting really thin aluminum and did get a smoother cut. Don’t know if that’s really good for the blade though, I wasn’t real worried about it as I don’t cut a lot of aluminum with a circular blade anymore, I use a bandsaw.
-- -Curt, Milwaukee, WI
View NiteWalker's profile
NiteWalker
1467 posts in 743 days
#5 posted 433 days ago
Never cut anything with the blade on your saw backwards. All it does is causes stress on the blade tip joint.
It doesn’t improve the quality of cut at all. I see this recommended a lot for cutting plexiglass on the tablesaw even though a 40 tooth general purpose blade works just fine.
K.I.S.S.
View Paul Stoops's profile
Paul Stoops
273 posts in 727 days
#6 posted 432 days ago
Yes, I am working on a project that required cutting aluminum extrusions and 1/4” plate. I bought a 100T Oshlun blade designed for cutting aluminum which worked superbly. I also bought a cheap face shield, which helped a lot to keep the chips out of my face.
As previously stated, your 60T blade will work okay. Spraying the blade with WD-40 before cutting helps, as well.
-- Paul, Auburn, WA
quartrsawn
#7 posted 432 days ago
Thanx for all the info and insights. I too never liked the idea of running a blade backwards.I have done this before with a Jigsaw and a metal cutting blade. Hot fliing metal chips may be an issue at the jobsite (retail store). Even with the jig saw I’ll use WD-40, can’t hurt.
View BobM001's profile
BobM001
390 posts in 497 days
#8 posted 432 days ago
A “triple chip” carbide is the preferred blade for cutting non ferrous metals. Get a tube of stick wax and cut into it with the saw running. Just enough to coat the tips will do the trick.
-- OK, who's the wise guy that shrunk the plywood?
View Rick L's profile
Rick L
511 posts in 1928 days
#9 posted 431 days ago
You certainly can and you might even have the correct blade on your saw. A triple chip grind and negative hook with around 60 teeth is the type of blade designed to cut non-ferrous metal. The negative hook is common on many miter saws and radial arm saw. You can use a positive hook on the occasional aluminum cut just go a bit slower on the cut. A face shield is nice as the chips aren’t really hot per se, just a bit warm.
As a Metalsmith I use many basic woodworking machines to work non-ferrous all the time including the table saw and router.
-- Few folks really know how to maximize the potential of their tools!
