Jointer Fence
Forum topic by Stephenw posted 03-13-2012 01:54 AM 1972 views 0 times favorited 8 replies Add to Favorites Watch
View Stephenw's profile
273 posts in 2319 days
03-13-2012 01:54 AM
I have an older Craftsman jointer. I squared the fence to the table with the square on the infeed side.
With the square on the outfeed end, I can see a gap I could drive a truck through. Well, it’s actually not as bad as it looks. That is a precision machinist’s square in the picture and the fence is out of square 1/64”.
Do I…
1. Twist the fence to try and spring it to perfection (while crossing my fingers, hoping the cast iron doesn’t break).
2. Are you crazy? That is a woodworking tool and the twist is perfectly acceptable.
3. Other?
8 replies so far
View ChuckV's profile
3102 posts in 3461 days
#1 posted 03-13-2012 01:58 AM
Is the fence twisted or are the two tables not parallel?
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
#2 posted 03-13-2012 02:03 AM
I think the tables are coplanar. I adjusted the infeed to the outfeed, inboard and outboard, with a Starrett precision straight edge.
You may have solved my problem. I have the infeed full down and it may twist on the stops. Let me check again.
I raised the infeed table to match the outfeed. That wasn’t the problem.
View Grandpa's profile
3259 posts in 2609 days
#3 posted 03-13-2012 02:11 AM
I vote to recheck the tables. Those are not co-planar. If you are just dead certain the tables are co-planar then the straight edge should not contact both ends of the fence. Then there is the unlikely chance that the fence is warped. Can happen but unlikely.
View Jorge G.'s profile
Jorge G.
1537 posts in 2409 days
#4 posted 03-13-2012 02:13 AM
Have you thought of putting a shim where the gap shows instead of trying to bend it? I would put a playing card or something like that and not worry too much about it.
-- To surrender a dream leaves life as it is — and not as it could be.
#5 posted 03-13-2012 02:21 AM
I think I agree that the tables are not coplanar.
I am going to try a different approach. Instead of adjusting so I think the straight edge is touching everywhere, I am going to lower the infeed table. Then I will measure the gap between the straight edge and the table, inboard fore and aft. Then outboard fore and aft. When all the gaps are the same, the table will be coplanar.
#6 posted 03-13-2012 02:45 AM
Infeed table is off a little, but it is almost bed time. I’ll fiddle with it a little tomorrow and post how I adjusted it.
#7 posted 03-19-2012 08:59 PM
I got a little side tracked and just got back to this today. I wrote an article on my blog about what I did…
View Martyroc's profile
2712 posts in 2239 days
#8 posted 03-19-2012 11:23 PM
Hi Steve, I had the same issue, fix was simple I mounted a 1/2 board to the fence and shimmed out the uneven portion until square. I gave up a 1/2” of the surface but it’s not that big and the only joint edging I have ever gone up to is 3” thick, acceptable for 4 1/2” jointer I think.
-- Martin ....always count the number of fingers you have before, and after using the saw.
