| Forum topic by Bob | posted 438 days ago | 1826 views | 1 time favorited | 15 replies | ![]() |
438 days ago |
Topic tags/keywords: bandsaw mobile base casters w1706 question I recently purchased the Shop Fox W1706 14” Bandsaw. It weighs 275 lbs and has a 18” x 15 1/2” footprint. The bandsaw sits on a closed cabinet. On the underside of the cabinet, at the corners, are 4 holes (in pretty thick looking plate metal) to accommodate the supplied bolts and rubber feet. My question is: Can I just replace the bolts with fully locking stemmed swivel casters rather than place the cabinet on a mobile base? I REALLY like the maneuverability that 4 swivel casters provides and I would like avoid the mobile base issues (not as maneuverable with fixed wheels, tilting top heavy equipment, price/quality, increased footprint). I would use a small diameter wide wheel (something like this). Would putting casters directly on the cabinet make the bandsaw any less stable/more tippable than just sitting on the supplied feet? |
15 replies so far
#1 posted 438 days ago |
I have a Jet 14” bandsaw on this mobile base. It is stable, and doesn’t raise it very much. http://www.woodcraft.com/product/2080750/33126/woodriver-universal-mobile-base-hardware-kit.aspx -- It must be jelly baby, cause jam don't shake like that... |
#2 posted 438 days ago |
I have a 14” GO555X mounted on a HF(large) furniture dolly. Maybe just a hair top heavy but works great. I roll it straight out from the wall and straight back in. -- Don't rollerskate in a buffalo herd |
#3 posted 438 days ago |
Bob, consider that those 3” swivel casters, the contact area with the floor also swivels and the supplied bolt holes are in a distance from the edge. You could have stability issues, I tried that path once, things got a bit interesting. |
#4 posted 438 days ago |
I tried using the small HF furniture dolly on my HF 14” BS and it was a bit small. I transferred the casterrs to a salvvaged oak cabinet door and it works great. 4-3” swivel casters for 8 bucks. -- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com |
#5 posted 438 days ago |
Howie and BorkBob, can you upload some pictures of your BS on its mobile base? |
#6 posted 438 days ago |
I grabbed some angle iron and some casters at the local Home Depot, and welded up a base that my Delta BS fits into. The angle iron keeps it from shifting in the base. It was cheap and it works. -- - The mightiest oak in the forest is just a little nut that held its ground. |
#7 posted 438 days ago |
My approach: casters and plywood |
#8 posted 438 days ago |
I built a base out of plywood 3 3/4 sheets then put my casters on then put some of those threaded inserts in when I get where I want I just screw a bolt down or in my case I have 6 bolts and mine is rock solid level but mine stays put except when I clean I would advise a good base just make it urself out of plywood and it will be better than what u buy but I have a 514×2b griz -- Stevo, work in tha city woodshop in the country |
#9 posted 438 days ago |
just get some of those neoprene casters they are easy to roll -- Stevo, work in tha city woodshop in the country |
#10 posted 438 days ago |
I have decided not to attach casters directly, but go with a mobile base. I have narrowed it down to 2 models: Jet 708118 JMB-UMB Universal Mobile Base The Jet is nice because you’re not tilting a top heavy piece of equipment. The main negatives I have read have to do with heavy tablesaws. The weight causes some flexing and the casters may not be stable enough when working something that requires some force. I don’t think these would be issues with a bandsaw (although the W1706 does weigh 275 lbs.). On the other hand, everyone seems to really like the WoodRiver and the base is more stable on feet. Bottom line for me, I am going to be moving this thing whenever I need to use it, so I want easy mobility. That has me leaning towards the Jet. My only hesitation is from stability concerns raised by some reviews. What do you guys think? |
#11 posted 437 days ago |
#12 posted 437 days ago |
@Bob
#13 posted 437 days ago |
After all of this, I decided on the Harbor Freight mobile base. Assembled it last night and it works great! I wrote a review of it (my first review). Check it out. |
#14 posted 437 days ago |
Fixed casters serve an often overlooked purpose. That purpose is to inhibit movement in one axis/plane. I would give up the ‘convenience’ factor for this added security, IMO. I use the Grizzly mobile base on my 14in Rikon BS and find the four locking casters to work very well. I have no problem moving the BS (on concrete) and can even nudge the BS sideways against the fixed wheel orientation when I need to adjust placement of the BS before use. Once locked down everything is fine. -- HorizontalMike -- "Woodpeckers understand..." |
#15 posted 429 days ago |
We use brick scaffolding casters which have a 3×3 square base plate atop the bearing housing. From this extends a 1 inch threaded rod about 20 inches long. Cut the rod off once you install them or leave in place (your choice). They are a bit pricey but the solid , large steel wheels with solid rubber “tires” make them ideal for heavier shop tables/equiptment. -- The minute my 42" Crick level LIES I'll kiss your ass ! |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3555 |
15813 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
