Can you help me identify this molding please?
Forum topic by noone posted 03-12-2012 05:27 PM 1647 views 0 times favorited 22 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2295 days
03-12-2012 05:27 PM
I am trying to identify the following molding so that I can use it on the built-in counter top I am constructing. Anybody know what this is and where I can get it?
I have access to Home Depot and also this millwork – http://www.mouldingandmillwork.com/pdf/IND6808_Orlando_Profile_Guide.pdf
22 replies so far
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2378 days
#1 posted 03-12-2012 06:00 PM
a typical chair rail, has other uses but that’s what it is.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View dannelson's profile
dannelson
193 posts in 2394 days
#2 posted 03-12-2012 06:03 PM
bed moulding
-- nelson woodcrafters
View DS's profile
DS
2924 posts in 2443 days
#3 posted 03-12-2012 06:05 PM
It is called “Half Astragal” and is fairly common at molding suppliers. Not sure about big box stores.
noone
#4 posted 03-12-2012 07:19 PM
i didn’t see it in this molding catalog-
This is the millwork that all the local lumber yards use here in Jacksonville, FL.
This would be even better:
404 - Not Found
2544 posts in 2992 days
#5 posted 03-12-2012 07:29 PM
Try looking for a ‘broken ogee’
noone
#6 posted 03-12-2012 09:06 PM
So many different answers across multiple forums as to what this is. I thought this was supposed to be a ‘stock’ type molding!
I can’t find it anywhere here in Jacksonville.
View bruc101's profile
bruc101
1200 posts in 3565 days
#7 posted 03-12-2012 09:43 PM
The top part looks like a door edge molding we use sometimes. It would be a simple molding to make if you made it in two pieces. We’ve made a drop edge on solid surface tops that looks just like it.
-- Bruce Free Plans http://plans.sawmillvalley.org
View devann's profile
devann
2246 posts in 2715 days
#8 posted 03-12-2012 09:50 PM
Chair rail molding. At least that’s what I was told to do it the last time I saw some.
noone
#9 posted 03-12-2012 10:02 PM
Thanks for the replies. I cant seem to put either of these examples together. Could any of you put some profiles together for me and name them from the catalog I linked to above? It’s what I have acces to here locally. Thanks again
View DS's profile
DS
#10 posted 03-12-2012 10:06 PM
There are two sizes. This particular supplier calls it “Lineal Edge”
Not sure if they ship.
View IrreverentJack's profile
IrreverentJack
727 posts in 2866 days
#11 posted 03-12-2012 10:10 PM
I would have said Bed Moulding but it is called Head Crown here. -Jack
Panel Moulding?
noone
#12 posted 03-12-2012 11:11 PM
Yep that’s it, “head crown”.
Where can I get it locally in Jacksonville, FL?
Or how can I build up this profile from here? http://www.mouldingandmillwork.com/pdf/IND6808_Orlando_Profile_Guide.pdf
View Trapshter's profile
Trapshter
64 posts in 2417 days
#13 posted 03-13-2012 12:08 AM
It’s called cove and bead. Very common. The variables are in the size of each section and overall height. You show it upside down looking at your picture the top is the cove,middle is fillet, bottom is the bead. Look at MLCS, Eagle,Whiteside. They all have it some offer it alone and others have in a multi bit.
-- Smile and wave boys just smile and wave
noone
#14 posted 03-13-2012 12:18 AM
“It’s called cove and bead. Very common. The variables are in the size of each section and overall height. You show it upside down looking at your picture the top is the cove,middle is fillet, bottom is the bead. Look at MLCS, Eagle,Whiteside. They all have it some offer it alone and others have in a multi bit.”
Do you have links for “MLCS, Eagle, or Whiteside”. I googled these and cannot find them online.
I know I keep asking but the ONLY place I know to buy molding in Jacksonville, FL is from lumber yards that use this supplier- http://www.mouldingandmillwork.com/pdf/IND6808_Orlando_Profile_Guide.pdf
PLEASE help me put together what you are referencing from this catalog for this picture. I can find the cove, but nowhere do I see a bead or fillet. I think what you are calling a ‘bead’ is basically a bullnose, or what is referenced in my catalog as a “half round”. Thanks again.
noone
#15 posted 03-14-2012 12:42 AM
Hmm, the more I look at this, the more I think that is a small piece of crown underneath a bullnose edge…...
