| Forum topic by Martyroc | posted 464 days ago | 551 views | 0 times favorited | 5 replies | ![]() |
464 days ago |
Hi fellow LJ’s, just a quick question, I have almost completed my cyclone DC, it’s made of 99% wood, however inside there is a short piece of 4” PVC, about 14-16”. Here is the question, since there is only one small part of the DC that is using PVC pipe inside the cyclone, do I need to run a bare ground wire through the pipe, or it’s not enough PVC pipe to generate that much static electricity? The piping in the shop will be flexible hose were I need to make turns, but the bulk of the piping will be sheet metal duct work, should that be grounded also? Thanks, if you want to see what I mean about the CycloneDC out of wood here is a link to my blog LINK -- Martin ....always count the number of fingers you have before, and after using the saw. |
