Using gold leaf on incised letters
Forum topic by unisaw posted 82 days ago 120 views 0 times favorited 7 replies Add to Favorites
View unisaw's profile
unisaw
10 posts in 574 days
82 days ago
I have finished my first sign and I used genuine 24 Karat gold leaf to finish the incised letters. The leaf came on wax paper sheets and was applied with mild pressure. I applied size just to the incised area but the gold leaf stuck to everything and I could not get it off. So – I had to touch up the field area and it looks crappy. The paint in the field is a an oil.
Does anyone kow how to prevent the leaf from sticking where you don’t want it?
View BertJ's profile
BertJ
49 posts in 140 days
82 days ago
New Yankee Workshop did a complete segment on just this technique a few years ago. Bottom line—it ain’t easy. But Norm walks you through the process with the help of several experts. Do a search on the segment and buy it. You’ll be glad you did.
View GaryK's profile
GaryK
8401 posts in 430 days
82 days ago
David Marks on Wood Works did it also.
View John Gray's profile
John Gray
579 posts in 327 days
82 days ago
I’ve done it over lacquer and I suck nowhere but to the sizing. Maybe its the finish you used? I put it on lacquer and covered it with enamel, you have to just dust it (spray painting) with enamel maybe 10 tomes to get the gold sealed so the enamel does not destroy it. After the dusting/sealing you can spray away with the enamel.
View Roper's profile
Roper
323 posts in 155 days
82 days ago
i worked in frame shop for a couple of years and what we would do is spray the whole thing with shellac let it dry then use blue tape to cover the areas you don’t want to size. remove the tape and the leaf will only stick to your letters,then seal with laquor. hope that helps a little.
-- Roper - master of sawdust-
View Max's profile
Max
5420 posts in 715 days
82 days ago
If you take a raw potato and cut it in half and rub it over the area that you do not want the gold leaf to adhere to it will stop it from sticking to that area. This is the process that Norm used as referenced by Bert J and has been used for many many years.
unisaw
82 days ago
Thanks all. The potato sounds like the trick.
Roper – I found the hard way that carpenters masking tape leaves a residue – enough to “grab” the leaf.
Can I size over the leaf and put on a second coat?
Roper
82 days ago
i tried doing that once and it did not turn out well. size doesn’t stick to the gold leaf very well and will fall off in time. you can use laquer thinner to rub if off,or sand it litely with 320 grit paper.
Bookmark And Share This Page
