How do YOU cross cut wide panels on a table saw?
Forum topic by noone posted 03-11-2012 02:44 PM 9662 views 0 times favorited 9 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2175 days
03-11-2012 02:44 PM
New to woodworking and was cross cutting my first cabinet sides yesterday on a table saw. I cut them down to be about 40” tall and 20” wide using a circular saw. Then I thought I would cut them down the rest of the way on the table saw to get perfectly repeated cuts. Well, the rips worked out great. But trying to cross cut 19” panel that is 40” tall proved to be a chore.
How do you guys cross cut accurately on a table saw? Use a sled?
I guess I could use the CS to crosscut to size but was hoping to be more accurate on the TS.
9 replies so far
View DIYaholic's profile
DIYaholic
19535 posts in 2578 days
#1 posted 03-11-2012 02:57 PM
You answered your own question. Crosscut sled is the answer!!! Do a search for crosscut sled, Super Sled & you’ll get more info than my little brain could possibly absorb!
Good luck, have fun, make sawdust & BE SAFE!!!
EDIT: Welcome to LJs. A great place to feed your (my) sawdust psychosis!!!
View HorizontalMike's profile
HorizontalMike
7747 posts in 2817 days
#2 posted 03-11-2012 03:11 PM
Bingo! A sled would help!
My sled can crosscut up to 22in, however, you can make a sled that can crosscut even more. The downside is that these sleds can eventually get too big to be practical. You will have to be your own judge as what is TOO big when it comes to TS sleds.
http://lumberjocks.com/projects/57667
View NormG's profile
NormG
5900 posts in 2907 days
#3 posted 03-11-2012 03:37 PM
Great Sled Mike,
Noone – it will also depend on the TS you are using as to the best way to approach the building of the sled
-- Norman - I never never make a mistake, I just change the design.
View Loren's profile
9935 posts in 3551 days
#4 posted 03-11-2012 04:09 PM
For crosscutting pantry sides you might want to make a sled
that runs on one side of the blade only to keep the weight
and size of the sled down and you can have the sled extend
out quite a ways to support the end of the panel…. over 20”
in your case because the panel is 40”, and with a long crosscut
fence on it. The sled doesn’t have to be rectangular or
square, it can taper on one side to support only 3 corners
of the panel: 2 corners next to the blade and 1 corner
on the outside… this way the sled can weigh considerably
less and you’ll fight the weight of it less.
View MrRon's profile
MrRon
4627 posts in 3146 days
#5 posted 03-11-2012 06:27 PM
I’ve seen it done by turning the miter gauge 180°, but I don’t know if it would accomodate a 19” piece.
View cutmantom's profile
cutmantom
401 posts in 2938 days
#6 posted 03-11-2012 06:36 PM
crosscut the 40” first then rip
View TheDane's profile
TheDane
5365 posts in 3566 days
#7 posted 03-11-2012 06:39 PM
I built a sled designed by Steve Maskery ( http://www.workshopessentials.com ) ... works great. I have been using it for well over a year, and have cut panels up to 20” wide.
Click for details
—Gerry
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2258 days
#8 posted 03-11-2012 06:40 PM
There’s more than one way to skin a cat, or cut a board.
Depending on the visibility of a 19” cut, I’d most likely use the sliding mitre, if the edges show up, I’d probably use a circular saw with a SHARP blade, and a straight edge guide. 19 inches is just going to be akward on most non cabinet makers saws.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View ajosephg's profile
ajosephg
1880 posts in 3464 days
#9 posted 03-11-2012 07:11 PM
I cut it about 1/8” long with a circular saw, and then trim it to size with a router and a clamp on guide.
I am too old and too weak to manhandle such a big piece on a table saw.
-- Joe
