Lacquer Finishing w/ air brush
Forum topic by RTJM27 posted 03-11-2012 02:44 AM 3969 views 0 times favorited 6 replies Add to Favorites Watch
View RTJM27's profile
RTJM27
32 posts in 2391 days
03-11-2012 02:44 AM
Topic tags/keywords: question spray gun finishing
I’ve made several clocks and have used several coats of lacquer to seal the faces. I usually use end grain pieces so the wood really soaks the lacquer up. A problem I’m having is that the final coat ends up uneven despite sanding between coats or not sanding at all. I’ve used foam and bristle brushes.
I’ve been told I could air brush the lacquer on so that it has a perfect even finish. I’m willing to spend some cash but can’t afford to buy something and then not use it.
?? So the first question, is this even possible to do with an air gun / brush, and second are there any good recommendations for kits, or guns??
I’ve got a 15 gal compressor that will generate 5.4 SCFM at 90 PSI.
Thanks in advance.
-- Reed
View Clint Searl's profile
Clint Searl
1533 posts in 2323 days
#1 posted 03-11-2012 09:03 PM
Rattle can lacquer from the borg is all you need.
View Sawkerf's profile
Sawkerf
1730 posts in 3030 days
#2 posted 03-11-2012 09:28 PM
I’ve sprayed gallons of lacquer with an HVLP setup. You could probably use an HVLP conversion gun dialing the pressure back to ~35 – 40 psi.
For something as small as a clock, a rattle can would be easier. No cleanup. – lol
RTJM27
#3 posted 03-12-2012 02:21 AM
Thanks a lot fellas.
-- Reed
View jumbojack's profile
jumbojack
1674 posts in 2586 days
#4 posted 03-28-2012 02:11 AM
i got a Critter, check it out on Amazon, it is under 40 dollars and does a bang up job with lacquer. MUCH cheaper than anything else and clean up is easy and fast. You will not be sorry.
View bruc101's profile
bruc101
1200 posts in 3504 days
#5 posted 03-28-2012 03:30 AM
What brand lacquer are you using?
-- Bruce Free Plans http://plans.sawmillvalley.org
View NiteWalker's profile
NiteWalker
2736 posts in 2539 days
#6 posted 03-28-2012 04:18 PM
I have the critter too ( I learned to spray with it) and it does well though it has a lot of overspray since it’s a conventional sprayer. Clean up is VERY easy.
Woodcraft has an airbrush set or a basic model. Both are inexpensive.
