Vintage power tools
Forum topic by dlayland posted 464 days ago 1587 views 1 time favorited 13 replies Add to Favorites Watch
View dlayland's profile
dlayland
11 posts in 580 days
464 days ago
I have an old Delta model 82-710 12” disk sander that has been sitting and rusting in the garage and various storage sheds since 1975. I got it out the other day and the motor ran smoothly. The problem is rust. I have never refurbished on old power tool and wonder if anyone has any hints on how to go about it. I let the motor run for several minutes and it never overheated or missed a beat. I figure if I could clean it up it would be a nice addition to my wood shop. Any thoughts would be appreciated.
-- Dave
13 replies so far
View dustbunny's profile
dustbunny
1149 posts in 1491 days
#1 posted 464 days ago
Evapo-Rust
Bought a gallon of it the other day at Harbor Freight.
Used it on my 1930 something Walker Turner scroll saw table top.
400, 600, 800 grit wet dry sandpaper…..Shines like the top of the Chrysler Building
Very little muscle involved. It does eat paint.
Try it.
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
dlayland
#2 posted 464 days ago
Thanks, Lisa. Will give it a try. there is a lot of rust. hope it works
-- Dave
dustbunny
#3 posted 464 days ago
I would try to debulk as much of the rust as you can with a wire brush first or even sandpaper.
Then bathe it.
Let us know how you make out.
Lisa
View MrRon's profile
MrRon
1631 posts in 1440 days
#4 posted 464 days ago
First I wirebrush heavy rust off; then use a sanding sponge and WD-40 [cast iron surfaces only]. Finish with pure Carnuba wax.
MrRon
#5 posted 464 days ago
Lisa, I’ll try that Evapo-Rust. Of all the machines in my shop, my HF wood lathe is the only one that rusts badly.
dlayland
#6 posted 463 days ago
Thanks everyone. I found a friend who had some and have started on the small pieces first. Will post a photo when I complete the refurbishing of the sander.
-- Dave
View TajBuilder's profile
TajBuilder
14 posts in 1776 days
#7 posted 462 days ago
When I restored my 1955 Powermatic 90, I cleaned up the headstock, tailstock and tool banjo using electrolosis. I made my “spooge” tank out of plastic muck bucket I bought at Tractor Supply. I lined the inside wall with sheet metal and ran a bolt through to the outside near the top of the bucket. I suspended the parts with copper wire from a steel bar across the top of the bucket and covered them with a solution of 1 part water to one tablespoon washing soda. Then I hooked up the negative feed from my battery charger to the steel bar and the positive feed to the bolt. I set the charger to 2 amps and let it work over night. It loosened all the rust and removed the paint. Many people prefer this to evaporust because no acid is involved and it doesn’t remove any of the good metal.
TajBuilder
#8 posted 462 days ago
When I restored my 1955 Powermatic 90, I cleaned up the headstock, tailstock and tool banjo using electrolosis. I made my “spooge” tank out of plastic muck bucket I bought at Tractor Supply. I lined the inside wall with sheet metal and ran a bolt through to the outside near the top of the bucket. I suspended the parts with copper wire from a steel bar across the top of the bucket and covered them with a solution of 1 part water to one tablespoon washing soda. Then I hooked up the negative feed from my battery charger to the steel bar and the positive feed to the bolt. I set the charger to 2 amps and let it work over night. The electric current loosens the rust and transfers it to sacrifical anode – in this case the sheet metal and rebar. Any loose paint is also removed and settles to the bottom of the tank. A scotchbrite pad or wire wheel removes any remaining residue. Many people prefer this to evaporust because no acid is involved and it doesn’t remove any of the good metal.
dlayland
#9 posted 462 days ago
That’s how mine looks. It just so happens we used to have horses and there are 2 muck buckets in my garage. Sounds like I might have some experimenting to do. your loathe is awesome looking.
-- Dave
View tomd's profile
tomd
1336 posts in 1966 days
#10 posted 462 days ago
Wow, that’s a beautiful job you did, it looks terrific.
-- Tom D
dustbunny
#11 posted 462 days ago
TajBuilder,
That is awesome !
I am restoring a Walker Turner Scroll/jig saw 1930’s.
I think I will try electrolysis for the bigger casting parts to remove rust AND paint.
The smaller parts worked nicely in the Evapo-rust. It is non-toxic and environmentally friendly.
I think it is concentrated citric acid. I have put my fingers in it and had no effects to skin.
(It was an accident, not on purpose.)
Here are the upper and lower vise chucks. They looked like the bolts in the upper right corner.
Both after Evapo-Rust for 24 hours, the left one after wiping and polishing. Not bad huh ?
Lisa
TajBuilder
#12 posted 462 days ago
Lisa -
Those parts look great. I used naval jelly on the ways of the lathe which is a similar solution. What I like about the spooge tank over evaporust is the solution never wears out so I think its cheaper in the long run. You just add water to replace what has evaporated. but don’t have to add any more washing soda. Several friends in my turning club made smaller tanks out of 5 gal plastic pails and you can use any ferous metal except for stainless steel for the anode. You don’t want to use stainless steel because it becomes toxic as it breaks down. Some people recommend against using galvanized metal because the zinc can end up plating the piece you are restoring. I didn’t find this was a problem and you can avoid the problem by changing the water.
Roy
View Bertha's profile
Bertha
12906 posts in 889 days
#13 posted 462 days ago
Dustbunny, I use electrolysis preferentially but evaporust on parts that’ll fit in a mason jar. I usually loosen up grime with a powered brass brush. I like the little pointy-ones that deform into tiny crevices. I used to use a rotary tool but the brushes really add up $. I’d estimate that 75% of the people I know who restore vintage use Evaporust. It’s good stuff.
