Saw Blade Cleaning
Forum topic by SuburbanDon posted 03-10-2012 03:09 PM 1342 views 0 times favorited 12 replies Add to Favorites Watch
View SuburbanDon's profile
SuburbanDon
487 posts in 3199 days
03-10-2012 03:09 PM
I have a carbide tipped circular saw blade that seems to be bogging down when I cut just about anything (lately maple). The blade tips seems sharp but I noticed hard gunk on the side of the tips.
Can somebody tell me what would be the best solvent I could use ? Money is an issue so I can’t send away for special saw blade cleaner. Thanks.
-- --- Measure twice, mis-cut, start over, repeat ---
12 replies so far
View FreshSawDust's profile
FreshSawDust
68 posts in 2535 days
#1 posted 03-10-2012 03:13 PM
Warm water with dishsoap and an old toothbrush works well for me.
-- TJ - Perryville, Missouri
View hunnypot's profile
hunnypot
36 posts in 3581 days
#2 posted 03-10-2012 03:14 PM
Try an oven cleaner like Easy Off
View syenefarmer's profile
syenefarmer
512 posts in 3286 days
#3 posted 03-10-2012 03:17 PM
Simple Green, 409, Goof-Off, etc. will work.
View RussellAP's profile
RussellAP
3104 posts in 2492 days
#4 posted 03-10-2012 03:18 PM
Kerosene will dissolve the crude and you can wipe it off with a rag. It’s likely sap from cutting pine. Kerosene works great for cleaning a lot of things around the shop and it can be reused if you just pour it back into a metal container. All the sediment just drops out of it when it sits.
View bruc101's profile
bruc101
1260 posts in 3747 days
#5 posted 03-10-2012 03:19 PM
I go with hunnypot, we’ve been cleaning our saw blades for years with Easy Off oven cleaner. Let it sit for a little while and if it’s really bad we go over it with a tooth brush and then wash it off with water…usually a water hose.
-- Bruce Free Plans http://plans.sawmillvalley.org
RussellAP
#6 posted 03-10-2012 03:24 PM
Hunnypot. Oven cleaner contains acids that will deteriorate the weld of the carbide to the steel. I wouldn’t use it to clean blades.
View Bill White's profile (online now)
Bill White
5135 posts in 4166 days
#7 posted 03-10-2012 04:03 PM
Simple Green and a brush. Ain’t puttin’ any oven cleaner on my high priced blades.
Spray it on, wait a couple minutes, brush it off, rinse in warm water, dry,and USE it.
Cheap and easy. What’s not to like? Doesn’t smell bad and bio friendly.
Bill
-- bill@magraphics.us
View knotscott's profile
knotscott
8154 posts in 3581 days
#8 posted 03-10-2012 04:40 PM
You’ll find dozens of blade cleaning discussions here if you search.
Just about any household spray cleaner works well….409, LA’s Totally Awesome, Fantastic, Greased Lightning, Goo Gone, etc. Spray it on, hit it with a brass or nylon brush, rinse, wipe…done in minutes. No need to buy aftermarket sprays. I’d also advise against oven cleaner…it’s caustic, messy, can remove lettering from your blades, and doesn’t work any better than something like 409. If the build up is really bad, Freud suggests a kerosene soak b/c it’s pH neutral.
Whichever method you choose, the important thing is to do it…dirty blades perform like dull blades, and the excess heat actually causes dulling. Clean blades perform better longer.
View Marlow's profile
Marlow
178 posts in 2876 days
#9 posted 03-10-2012 05:10 PM
CMT Bit/Blade Cleaner: works great.
SuburbanDon
#10 posted 03-10-2012 08:10 PM
Thanks for the info. I ended soaking the blade in paint thinner which probably didn’t help much. Then I used squared off popsicle sticks to get the gunk off (60 teeth, four surfaces each). It took about 15 minutes. There was a lot of crud. I then found that alcohol was pretty good for getting the residue of of the blade body itself.
Moral of the story: Clean the blade more often, avoid pine, find something to soak it in that will do most of the work.
Oh yeah and I can bare witness to the fact that those tips are still sharp !
View johnintecumseh's profile
johnintecumseh
127 posts in 3622 days
#11 posted 03-10-2012 08:34 PM
Don the best for cleaning blades is Borax ,or similar, in warm water . let soak then use a toothbrush . after drying use Bostitch blue spray . you’l be good for a while. keep smiling John
-- retired and smiling
Bill White
#12 posted 03-10-2012 09:15 PM
Yep! The borax is good too. I used to be able to find Arm & Hammer Washing Soda which is what I used for a long time. Now find it hard to locate.
Bill
