Sealer For MDF?
Forum topic by gfadvm posted 03-10-2012 12:35 AM 4282 views 0 times favorited 24 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2891 days
03-10-2012 12:35 AM
I just built a 4’x6’ assembly/finishing table and am covering it with MDF. What would be best to seal it to keep glue, finish, etc from sticking to it? Thanks in advance.
24 replies so far
View DonnyBahama's profile
DonnyBahama
215 posts in 2733 days
#1 posted 03-10-2012 12:42 AM
Hi, Andy! I think what most people do is top it off with a sacrificial sheet of 1/8th inch Masonite.
-- Founding member of the (un)Official LumberJock's Frugal Woodworking Society - http://lumberjocks.com/topics/29451
View HorizontalMike's profile
HorizontalMike
7770 posts in 3115 days
#2 posted 03-10-2012 12:49 AM
Johnson’s Paste Wax, cheap and works well.
View Clint Searl's profile
Clint Searl
1533 posts in 2563 days
#3 posted 03-10-2012 01:14 AM
Varathane waterborne poly for floors.
View Howie's profile
Howie
2656 posts in 3124 days
#4 posted 03-10-2012 01:21 AM
I used poly on mine then like Mike says,Wax it.
-- Life is good.
View Sawkerf's profile
Sawkerf
1730 posts in 3270 days
#5 posted 03-10-2012 01:23 AM
I use water based poly – often whatever is in the can from projects. About once a year, I scrape it down and give it a fresh coat.
gfadvm
#6 posted 03-10-2012 01:26 AM
Mike, The wax would be easiest but I was comcerned that MDF will just soak up wax like a sponge? No finish under the wax? Donnie, Glad to hear you’re up right and taking air.
View Bobsboxes's profile
Bobsboxes
1369 posts in 2865 days
#7 posted 03-10-2012 01:29 AM
Andy, I have alot of mdf counter tops in my shop and I put a couple coats of poly on it. You can hit any glue stuck to it, after it drys, with a puddy knife and it peels up. The nice thing about poly is you can scuff it up, hit it with a sander and recoat it and it looks like new. I have built several roll around tool boxes and I put a piece of 1/4” hard masonite on top, so it is easily replaced. Also coated that with poly. Then just plain old johnson floor wax.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View lizardhead's profile
lizardhead
652 posts in 3043 days
#8 posted 03-10-2012 01:31 AM
I covered mine with a clear sheet of Plexiglas, I just use a 1-1/4” chisel to remove any glue, trust me I use it a lot
-- Good, Better, Best--Never let it rest---Always make your Good be Better & your Better Best
View Roger's profile
Roger
20952 posts in 3005 days
#9 posted 03-10-2012 01:37 AM
I know both water base poly, Johnsons paste wax are gr8. glue comes right off. @lizardhead: plexi? hummm sounds interesting.
gfadvm
#10 posted 03-10-2012 02:11 AM
Thaks for all the quick input. I guess poly won the contest. Now, how many coats should I apply? I think I’ll use water based as I have some that I will never use otherwise (and it should dry quicker).
View vonhagen's profile
vonhagen
540 posts in 2566 days
#11 posted 03-10-2012 02:32 AM
you could use formica and just contact cement it on and nothing will stick to it but you must use a backer on the other side so it wont warp. my main work bench is 1 3/4×6 poplar frame with 3/4 mdf with standard grade formica and i just use saw horses and level it with shims and it also works on the floor as a nice level flat surface to mock up large pieces. never use wax on your work surface as it will transfer to your wood and screw up your finish
-- no matter what size job big or small do a job right or don't do it at all.
gfadvm
#12 posted 03-10-2012 03:02 AM
Hey Blaine, My workbench is covered with Formica and I love it but don’t want to spend $50 to cover this table so Polyacrylic looks like the plan for tomorrow.
Roger
#13 posted 03-10-2012 04:03 AM
I’d say at least 3. my $.02
vonhagen
#14 posted 03-10-2012 04:33 AM
go poly
View Helkat's profile
Helkat
74 posts in 2497 days
#15 posted 03-10-2012 02:43 PM
I used Spar urethane on mine, about 3 coats as is got sucked in pretty good by the mdf. At the time I was in a basement that flooded regularly, and I was concerned about it sucking up moisture and expanding over time so I did all sides.
Still holding up good for me.
-- Nat, UPstate NY, http://www.cordlessimpactdriverhq.com/
