| Forum topic by HokieMojo | posted 92 days ago | 129 views | 0 times favorited | 5 replies | ![]() |
92 days ago |
I own a lot of craftsman tools and I guess about 3 of these tools have a laser line feature (scroll saw, circular saw, and mitre saw). I think the only tool that has a truly meaningful laser on it is the mitre saw. The other two help you cut a long straight line, but if you really want it to be straight, you will use a straightedge. Anyway, I’m wondering how accurate this feature should be. The laser on my saw is probably about 2mm thick. the brightest part is probably 1mm. I don’t feel like the line is all that crisp though. It is actually enough that I still just pull the handle down to see where the teeth wil make contact with my board. Should I jsut be using the laser for a reference, or should I be able to rely on it for the cuts themselves. Just wondering. |
