What Material
Forum topic by bhack posted 03-07-2012 10:24 PM 912 views 0 times favorited 2 replies Add to Favorites Watch
View bhack's profile
bhack
349 posts in 3720 days
03-07-2012 10:24 PM
Topic tags/keywords: question
What material would I use to make the sides? The overall height would be 4.5 to 5 feet. My son ask if I could make one for new grandchild’s room, so Grandpa said he would research it.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
2 replies so far
13604 posts in 3341 days
#1 posted 03-07-2012 10:48 PM
i’d do 3 layers of 1/4” ply laminated on a form
(maybe oak if stained or reg if painted)
shelve dado-ed in
back in a rabbet
View DS's profile
DS
2917 posts in 2420 days
#2 posted 03-07-2012 10:57 PM
Two layers of “Kerfcore”, or, two layers of “Wigglewood” should do the trick.
Kerfcore: Usually mdf that has saw kerfs cut at regular intervals on the backside. By gluing two layers back to back a rigid curved panel can be made.
Wigglewood: a 3 ply plywood where the only cross grain ply is in the center and is fairly thin and flexible in one direction. Two layers glued together will produce a rigid curved panel.
Which one you use depends on which school of thought you’re aligned with. (And perhaps what is available to you)
I prefer wigglewood myself.
