| Forum topic by mtappe | posted 442 days ago | 1136 views | 0 times favorited | 8 replies | ![]() |
442 days ago |
looking into putting a Steel City Industrial fence on Ridgid R-4511 Table saw any thoughts and if i wire my saw to 240 volts/220 do i need to put a different switch on the table saw? |
8 replies so far
#1 posted 442 days ago |
Instead of spending $450 on an import Biesemeyer clone, you could spend $420 and get the real deal. http://www.amazon.com/DELTA-BC50-Biesemeyer-Commercial-System/dp/B000NW44XE you could probably find it cheaper; I just did a cursory search. You could also go used and save some money that way. I don’t know for certain about that particular saw, but it’s a safe bet that a new switch will be required for 240v. -- Rory // Winter Sun Woodworking // Milwaukee, WI |
#2 posted 442 days ago |
I got a great deal on a Biesmeyer rails, tube and fence. It was a fairly easy install except I had to drill a couple of the holes in the rails. Fortunately I could use the old rails as a template. Unlike cast iron tops, you can’t drill holes where needed in the granite tops. Thats a good reason to buy the Steel City, if the holes do match up and I don’t have any reason to think they won’t. I replaced the Ridgid back rail too so it would support a router table between the wings. Here is a link to a description of the process: Link Don’t know much about electricity, but my guess is that you would have to change the switch. Good luck and let us know how it turned out. -- Trees, a wonderful gift --Joe-- |
#3 posted 442 days ago |
I just got the r4512, it’s got a great fence, I would like another table extension for it though. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#4 posted 442 days ago |
Steel City made that saw for Ridgid, that is why the rails are direct bolt on. I would go with the SC fence, they make great product, and the fence will be way better that the one that is on your saw now. I just recently put a saw stop fence on my TS3660 and it was the best upgrade that I have ever made. |
#5 posted 441 days ago |
Biesemeyer 50 fence for $389 shipped. -- He who dies with the most tools... dies with the emptiest wallet. |
#6 posted 441 days ago |
Having a matching bolt pattern would be a nice way to go. I put a Delta T-2 on my R4511 and it has made a huge difference in operating the saw. I got two holes to line up but I really need to go back at some point and drill out the other two. T-2 was about $150 and a lot of people have made that worthwhile upgrade. I think the R4511 manual addresses rewiring to 220v, but I would have to go back and look to see if you need a new switch. |
#7 posted 441 days ago |
Yep, I have the T2 on my table saw (delta 36-979) and it works great, stays accurate. -- He who dies with the most tools... dies with the emptiest wallet. |
#8 posted 441 days ago |
Yes, the stock R4511 switch will handle either 120VAC or 240VAC. The manual describes the wiring change required—it is very simple. -- Paul, Auburn, WA |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
