| Forum topic by DevilDogNurse | posted 469 days ago | 452 views | 0 times favorited | 3 replies | ![]() |
469 days ago |
Hey all, I’m needing a real workbench, and have decided I want to try my hand at making a super heavy top comprised of face jointed 2×4’s. Now the tools I have available are a 6” bench top jointer, a Jack Plane and a hand held power planer. I know that the bench jointer can give me two sides (a 2 & a 4) that are flat, true and at 90’ angles. My problem, is how do I go about getting the other face (4”) that is parallel to the first without a thickness planer. I’d love to go and buy one, but….. I’m broke. ;-) So…. Do I just face joint both sides and deal with the eventual taper that’s going to form? Maybe alternate the pieces so the taper is alternating? Along the same lines, Since I don’t have any way to set the finished thickness of the boards, the bench top is most likely going to be uneven and irregular. Do I just attack with the jack plane and work it till its flat… ish? TIA all! Billy -- Marine, Nurse, Dad. |
