12" Rockwell contractors table saw.
Forum topic by madts posted 03-07-2012 06:19 PM 13847 views 0 times favorited 16 replies Add to Favorites Watch
View madts's profile
madts
1855 posts in 2308 days
03-07-2012 06:19 PM
All. I have this Rockwell 12” contractors table saw and it is 34 years old. I need parts for it and can not find the model # for it. I can find the motor # because it is right on the motor, but the saw model # is nowhere to be found. Any ideas?
-- Thor and Odin are still the greatest of Gods.
16 replies so far
View mafe's profile
mafe
11643 posts in 3058 days
#1 posted 03-08-2012 01:02 PM
Sorry no idea.
Best thoughts,
Mads
View chrisstef's profile
chrisstef
17311 posts in 2975 days
#2 posted 03-08-2012 01:36 PM
Hmmm .. it should start wit ha 34 – xxx number somewhere on it. You can try over at vintagemachinery.org theyve got all kins oif great info over there. I cant imagine that there is a ton of 12” saw made by rockwell so it shouldnt be too hard to track down.
View Ben's profile
Ben
302 posts in 2299 days
#3 posted 03-08-2012 01:40 PM
I’m with chrisstef, vintage machinery is where I would look first.
-- Welcome to downtown Coolsville, Population: US! --Hogarth Hughes
chrisstef
#4 posted 03-08-2012 02:15 PM
ah hah … its an odd ball for sure but i did find a parts breakdown … http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/delta/34-388
http://vintagemachinery.org/pubs/detail.aspx?id=3710
Looks like its a 34-388
I only found 2 that were for sale on the web. From what ive gathered they only made this saw for 2 years or so. Some unisaw parts will fit this saw.
madts
#5 posted 03-08-2012 04:35 PM
Thanks all. I bought this saw new when I first came to the States in 1980. It is not fancy but it has kept on working and working. Now it needs parts. The handles to raise, and angle the blade.
View quartrsawn's profile
quartrsawn
146 posts in 3182 days
#6 posted 03-08-2012 05:12 PM
Try www.ereplacementparts.com they have a Delta 34-388 listed , looks like it might be the same machine.
-- Nat - West Sayville,L.I., NY
View Mattfinisher's profile
Mattfinisher
71 posts in 1854 days
#7 posted 12-20-2013 07:42 PM
I just inherited the same exact saw from my grandfather, and the motor bogs when cutting even plywood, anything I can do to fix this, inexpensively?
-- “Anyone who doesn’t think money is grown on trees hasn’t bought any lumber lately.” www.facebook.com/johnsonandsons72
madts
#8 posted 12-20-2013 08:06 PM
2 things come to mind. The motor is full of dust, blow it out. Or put a new blade on it. New blades can do wonders.
View vanillabear1313's profile
vanillabear1313
1 post in 1119 days
#9 posted 04-02-2015 04:12 PM
I too have this exact saw, I’ve had a hell of a time getting the blade to true up to the miter gauge slots. Any suggestions or idea’s? I’m also in search of a manual for it if anyone has one?
Thank you very much!!!
-Justin
View Bluepine38's profile
Bluepine38
3379 posts in 3054 days
#10 posted 04-02-2015 04:28 PM
The knobs are probably the same as the Delta Unisaw and Delta Cabinet saw. Check the part numbers on
the two parts lists shown, The main problem is parts are gettilng hard to find for the older Delta equipment.
Let us know how this turn out.
View unbob's profile
unbob
808 posts in 1872 days
#11 posted 04-02-2015 04:48 PM
The saws can also be branded Delta, here is a parts list.
http://vintagemachinery.org/pubs/1141/3710.pdf Not much different then the 10” version I have The hand wheels are smaller then the Unisaw, and mounts are different. Best bet on spare parts are ebay. Most parts are the same as the 10”, except the tie bars.
madts
#12 posted 04-02-2015 05:19 PM
All: I got the parts some time ago. Had to wait 1 1/2 years for some of then. Runs and cuts great.
Vanillabear: It can be cumbersome to align the blade to the miter slots. You have to get underneath and loosen the bolts that hold the arbor in place. I used a dial indicator to check for parallel.
Thanks for all your help.
View Rrhizae's profile
Rrhizae
1 post in 155 days
#13 posted 11-22-2017 02:59 AM
I’m considering buying this saw. $200 but the motor is not mounted on the saw and there’s a manageable bit of rust. He said he inherited it and has never used it. There’s no wiring, but he said hooked it up at one point and it runs. i like that it has a 12” blade, but is it under powered for it?
I need a very accurate, high powered saw that can cut 8/4 hardwoods +
Would any of the owners of this saw recommend that I buy it and put the effort into fixing it up?
madts
#14 posted 11-22-2017 10:36 PM
Yes, Yes, and Yes.
==Madts.
View knotscott's profile
knotscott
7983 posts in 3344 days
#15 posted 11-22-2017 11:45 PM
...I need a very accurate, high powered saw that can cut 8/4 hardwoods +
- Rrhizae
A very accurate, high powered saw that can cut 8/4 hardwoods + for $200 is a tall order. I’d be inclined to hold out for a true 3hp cabinet saw.
