Dark Stains on Mahogany after sanding
Forum topic by Airwreck posted 03-07-2012 08:17 AM 4334 views 0 times favorited 5 replies Add to Favorites Watch
View Airwreck's profile
Airwreck
2 posts in 2269 days
03-07-2012 08:17 AM
Hope someone has a solution or answer to what is going on with this mahogany table..
My wife started to refinish the table she stripped the old finish off and started to sand the surface..At the end of the day it was looking grand ..
The next day was the shocker.. these weird brown stain (spots) appeared …
so she decided to sand again the brown spots disappeared with minimal sanding… she was a happy camper..
till the next day…they were back..
This is tropical mahogany.. the table is about 100 yrs old..
here are some images of the irritating spots.
any ideas on how to deal with them would be greatly appreciated
5 replies so far
View RogerM's profile
RogerM
792 posts in 2396 days
#1 posted 03-07-2012 01:51 PM
I have never seen this situation in mahogany. It appears to be an oil that is bleeding out of the pores after sanding. One possible way to deal with it is to work with it by putting a coat of boiled linseed oil on it then finish from there. Wish I could be of more help.
-- Roger M, Aiken, SC
View bondogaposis's profile
bondogaposis
4727 posts in 2348 days
#2 posted 03-07-2012 02:16 PM
I think what is going on is that the original finish was an oil finish and some of it is still there. I may not be possible to remove all of it w/o sanding all of the wood away. What did you have in mind for the new finish? I would let it sit for a few days and see what happens. I think that you probably can’t fight it and I would look at using an oil finish or an oil modified urethane. I would really do some experimentation on the under side of the table before making a final decision. Why did the table need refinishing, what type finish was it? Let’s hope those spots aren’t from some type of silicone.
-- Bondo Gaposis
View tenontim's profile
tenontim
2131 posts in 3741 days
#3 posted 03-07-2012 02:44 PM
I’ve gotten rid of these by wiping down the wood with M.E.K. Lacquer thinner may work in a pinch. Let it set for a day to make sure nothing else bleeds out.
Airwreck
#4 posted 03-08-2012 02:02 AM
I thought it was something oil based. the way it appears is that kind of behavior.. Just needed the conformation.. Yeah I have never seen this before.
Because of the age of the table it is very unlikely that there is anything silicone base involved.
HA :-) the reason the table is being refinished is you have to see the way that Bajan Joiners have been finishing wood here for centuries.. They had this idea that you need to HIDE the grain of the wood and slathered on, for a better word, this brown shoe polish.. and they did it to all their wood projects.. This disease has not appeared on any other wood products that had this same shoe polish
after she my wife recently refinished these pair of small three leg tables that were nothing really special… but after she was done they looked wonderful.
Not sure if we can get M.E.K. here but will look into it..
If all else fails break out the linseed oil…
Thanks a million guys
View tom427cid's profile
tom427cid
294 posts in 2467 days
#5 posted 03-08-2012 02:24 AM
When I strip and after the final rinse,I let it dry and then wash two or three times with DA. Generally does the trick. It appears what is happening is stripper is bleeding back. As was said earlier if the DA doesn’t work MEK should do the trick. Be patient and give the piece a day or two to dry between steps.
Hope this helps.
tom
-- "certified sawdust maker"
