Harbor Freight Model 98194 Miter Saw
Forum topic by Jim001 posted 03-07-2012 08:17 AM 2374 views 0 times favorited 2 replies Add to Favorites Watch
View Jim001's profile
Jim001
3 posts in 2394 days
03-07-2012 08:17 AM
Hello, I am new to the forum and hope to be a regular user. I just recently bought the Harbor Freight # 98194 Miter Saw and right off the bat, the laser did not work. Harbor Freight sent a replacement and received today. Well, I am having problems with adjusting it and not sure with the screw arrangements, which one dues what. Has anyone been thru this process and able to ajust? I would appreciate any help. Jim001
2 replies so far
View fussy's profile
fussy
980 posts in 3172 days
#1 posted 03-07-2012 09:15 AM
Jim,
I am not sure a laser of that type is worth fooling with. It seems, from what few pictures I could find in the manual, to be about the same thing that Penn State Ind. sells, and that is a piece of crap. The basic saw you have is a wonderful deal even without the laser. Tweak it so that it cuts true (easier to do and holds adjustment better than you would think possible) so that at least you can cut with it. If you have to have the laser do as I did on my 10” HF scms years ago. I used a HF 96401 laser disc that goes in place of the outer arbor washer with a longer (provided) bolt. It uses 3 button cells that last a good long time. With it, there is no adjustment. It simply shines along the left side of the blade and shows right where it’s gonna cut. I have used mine for 4 or 5 years with excellent results. Use a 20% off coupon to save some of the $15 price, or wait for a sale (inevitable). Got mine for $6. They are in store only, but look about, you’ll find one.
Steve
PS: Welcome to LJs
View ggicollegepunjab's profile
ggicollegepunjab
1 post in 2393 days
#2 posted 03-07-2012 09:36 AM
Some screws related that. Check the laser again it will be properly work after some times.
-- GGI Punjab
