Forum topic by Eric posted 03-07-2012 02:30 AM 980 views 0 times favorited 2 replies Add to Favorites Watch
View Eric's profile
221 posts in 2442 days
03-07-2012 02:30 AM
What’s the difference between HVLP and a regular pneumatic spray gun off an air compressor…. like for automotive?
-- Eric
2 replies so far
View Sawkerf's profile
1730 posts in 2999 days
#1 posted 03-07-2012 02:42 AM
Pure HVLP uses a turbine for it’s air supply and runs at high volume but low pressure air.
An HVLP conversion gun runs on a “normal” air compressor, but you need to reduce the pressure and use hose large enough to provide adequate volume. You also need a compressor tank with enough vilume to spray for a while without waiting for the tank to recharge.
-- Adversity doesn't build reveals it.
View wisno's profile
88 posts in 2942 days
#2 posted 03-09-2012 08:15 AM
HVLP is the modification for the air spray gun. He uses the “high volume” air pressure to do the atomization. The air pressure is kept in the low pressure to increase the efficiency of material transfer.
It is rather limited to work with material with low viscosity, but it works well for most of finishing material for wood finishing.
You can find more information in this link: hvlp spray gun for wood finishing
good luck
