Rigid 3650 blade flutter
Forum topic by yammi450 posted 03-06-2012 06:18 AM 1076 views 0 times favorited 8 replies Add to Favorites Watch
View yammi450's profile
yammi450
25 posts in 2536 days
03-06-2012 06:18 AM
I bought a used rigid 3650 about a year ago. I had no problems with it ( that I noticed) until one day I had a kickback. Ever since then it’s had a blade flutter or more of a hermonic (it comes and goes once I hear it comming I stop the feed but it amplifies enough to ruin the cut and then stops). It doesn’t happen when Im plowing through a cut at a good rate, It’s only when I’m going slow, trimming less than 1/8”, or on thin material. I’ve tried new blades, aligning everything to .002” or less, new bearings, new arbor, adjusting the belt tension, tightening all bolts, and checking for any runnout or excess play. I’ve got this thing adjusted perfectly. The only other thing I can think of is maybe getting a stablizer for the blade. If anyone can give some other options I’m open for sugestions.
Oh, the blade is a new Freud 1/8’” kerf, but it does it with other full kerf blades too.
8 replies so far
View 1yeldud1's profile
1yeldud1
301 posts in 2916 days
#1 posted 03-06-2012 10:38 AM
Have you replaced the belt ? —It may have a “weak” spot in it
View ShipWreck's profile
ShipWreck
557 posts in 3627 days
#2 posted 03-06-2012 11:06 AM
I am shooting from the hip here, but….....
1. Is the belt glazed over, or any strange looking wear patterns?
2. Trunnions tight to the table?
3. Motor secure on it’s bracket?
4. Possible pulley loose?
Really hard to tell without seeing it up close and personal.
Good Luck Yammi, I hope you get it figured out.
View knotscott's profile
knotscott
7821 posts in 3250 days
#3 posted 03-06-2012 11:40 AM
No idea really, but belt was one component that entered my mind….it’s cheap and easy too.
View Howie's profile
Howie
2656 posts in 2797 days
#4 posted 03-06-2012 11:52 AM
What Shipwreck says.
If you find out what it is, let me know. I have a 3650. So far no problems though.
-- Life is good.
yammi450
#5 posted 03-06-2012 03:01 PM
I’ll try replacing the belt, but everything else is tight.
Thanks for the input. I wonder if the belt is a special order thing.
1yeldud1
#6 posted 03-06-2012 06:05 PM
A lot of times a well stocked auto supply store might have a replacement belt for machines
View DIYaholic's profile
DIYaholic
19486 posts in 2549 days
#7 posted 03-06-2012 06:22 PM
Try a link belt. HF has an inexpensive (notice I didn’t say cheap) one, that gets great reviews. I just recieved one that will go on my TS.
yammi450
#8 posted 03-06-2012 07:34 PM
The belt isnt a v belt, it’s a 1/2” ribbed belt like a serpentine belt
