| Forum topic by sillac | posted 470 days ago | 1019 views | 0 times favorited | 12 replies | ![]() |
470 days ago |
Topic tags/keywords: router Working with a friends Craftsman router 315.25070, it stopped running in a heavy cut, it was warm but not really hot, and now won’t restart. Is there a reset on it? Is it toast? If so, what should I get to replace it? Thanks for any insight any of you can give me. -- Steve in Oregon, |
12 replies so far
#1 posted 470 days ago |
Sounds like you melted some solder in the field windings. If it stinks bad like burnt wiring, its toast. Porter cable makes a great replacement and your buddy will thank you. -- Denis in Grande Prairie. Yesterday is history, tomorrow is a mistery, but today is a gift. That is why it is called the present.....Pink ! |
#2 posted 470 days ago |
Thats the thing, there was no smell and the housing wasn’t very hot. -- Steve in Oregon, |
#3 posted 470 days ago |
Have you checked the brushes ? -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#4 posted 470 days ago |
Check the brushes. I’ve has them fail under a heavy load. |
#5 posted 470 days ago |
Most equipment now days has a thermal breaker. I assume you waited awhile and tried again. At that point I would say it is toast and would tend to agree with Denis! -- Folly ever comes cloaked in opportunity! |
#6 posted 470 days ago |
look at the brushes and while you are there take the top cover off and look for debris in the switch. If it is like mine it has a cable that goes to a micro switch and it can collect wood chips there causing problems. Just remove the plastic end cap and look into the top end of the motor. |
#7 posted 470 days ago |
Those models had trouble with the switch in the handle. Maybe it just needs cleaning. Dust gets in and dosn’t let the on-off switch contact properly. -- "My mission in life - make everyone smile !" |
#8 posted 470 days ago |
Mine has a cable from the handle to the switch with the switch located in the upper motor housing. It could be anywhere along the cable I suppose but my problem has been in the end of the motor every time. My problem was a little larger than dust. It was small wood chips. They occupy real space. |
#9 posted 470 days ago |
I burned up the old one I inherited from my dad (trigger pushes cable to switch in top) years ago. I was pushing it to hard with a 3/4” cutter and the shaft flexed enough to cause the cooling fan blades to colide with the housing…. Not pretty!! I just recently discovered that I also had a box with just about every Craftsman router accessory they ever made. So I picked up a similar but slightly newer model on ebay (switch is in the trigger handle) for a whopping $19. If I didn’t have all the accessories, I wouldn’t have bothered. IMO, you really need a 1/2” collet for any heavy routing. -- Pine is fine, but Oak's no joke! |
#10 posted 469 days ago |
most likely the brushes. -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
#11 posted 469 days ago |
Most people think that routers run on electricity…this is false they run on magic smoke…if the magic smoke comes out they don’t run anymore |
#12 posted 469 days ago |
doughan, what you just described is the brushes going,replace the magnetic brushes and, they work again! -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
| Forum | Topics |
Woodworking Skill Share
8847 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15983 |
Hand Tools
2098 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
