| Forum topic by Julianos | posted 444 days ago | 651 views | 0 times favorited | 7 replies | ![]() |
444 days ago |
I am building a bookshelf that uses both dowels and grooves in the assembly. The dowels join 3/4” boards at right angles. The grooves join 1/2” vertical boards to 3/4” horizontal boards. All joints bear vertical loads. I seem to have found a consensus indicating that 3/8” diameter dowels would be appropriate. Those sources also recommend using a dowel that is twice the length of the depth of the hole in the thinner piece of wood. So, even assuming that I bore a 3/8” deep dowel hole, that makes for a really short dowel. Any help with this would be appreciated. |
7 replies so far
#1 posted 444 days ago |
I’m not that found of using dowels ,I’m wondering why you can’t just use glue in dados. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#2 posted 444 days ago |
I would think that they might be talking about twice the thickness of the thinner piece of wood, which might be seen as the depth of that hole. So joining the two 3/4 pieces would use 1 1/2” dowel length, with a 3/4” hole in the end grain of the right angle board. And if you groove (dado) 1/4” deep into your 3/4” horizontal board, and then glue and dowel the 1/2” board into the slot, then this would be a 1/4” diameter dowel that is 1” long. The dowel would be half the thickness of the end grain board, and twice the thickness of the depth of the hole in the other. Does that make sense? Also, I would cut the dowels about 1/4” or so long. Then glue and pound them in place. After the glue dries then saw off the dowel flush. You can get them pretty nice looking after they are cut and planed/sanded. Good luck! And sorry if I completely missed the point here :) -- Dale, Oregon |
#3 posted 444 days ago |
If by grooves you mean dados, why would you add dowels? Shelves are supported in dados all the time, without dowels. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 444 days ago |
Jim, I’m working from plans. They are admittedly vague on this topic, though. Souichiro, if I use a 1 1/2” dowel and drill a 3/4” hole in the end grain, the other hole will go through the horizontal board. Or am I misunderstanding your suggestion? Crank, Sorry, I was unclear. There are three vertical pieces between each shelf. One of them is a half inch thick. That piece is fitted with dados in the horizontal shelves above and below. The other two vertical pieces are three quarters of an inch thick and joined to the horizontal shelves with dowels. So the dowels are only used in the three quarter inch vertical to three quarter inch horizontal joints. |
#5 posted 444 days ago |
I’d say 3/8” dowels that are 1 1/2” long. ~if~ you doweled the 1/2” material it should be a 1/4” dowel that is 1” long. But these aren’t really needed if the dado is glued, although it doesn’t hurt. -- Dale, Oregon |
#6 posted 444 days ago |
”Those sources also recommend using a dowel that is twice the length of the depth of the hole in the thinner piece of wood. ” The depth of the hole has no specific correlation with the |
#7 posted 444 days ago |
The vertical pieces are not vertically aligned, so I am not drilling both sides of the 3/4 horizontal. The reference to 5/8” is most appreciated, though. I had assumed that drilling to within 1/8” of the opposite surface would be inadvisable. Thanks. |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15804 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
