| Forum topic by normrep | posted 440 days ago | 704 views | 0 times favorited | 5 replies | ![]() |
440 days ago |
I’ve been working with quartersawn white oak on a dresser for my wife. I’ve read about imitating a stickley mission oak finish by starting with staining, then covering with sanding sealer, then wiping on and quickly wiping off a darker gel stain, then finishing with several coats of wipe-on poly. I tried this on a different project with good results, but now wondering why I couldn’t just use one thin coat of wipe-on poly in place of the sanding sealer. Would it seal the stain in, yet allow the gel stain to shade the open pores of the oak without changing the base stain color? Also, I’m wondering if I could use Minwax poly-shades for the first coat and do the sealing and staining in one step before wiping in the gel stain to darken the pores. Of course, I will have to experiment with all of this on test scraps before going to the project, but I wondered if some of you have worked with a similar process and can give me a heads up on what I might expect, or any helpful tips that might allow me to avoid a few headaches. I might also mention that I don’t have any spray equipment, so I’m limited to brushing or wiping – and I would like to find ways to go almost entirely to wiping in the finish process. I’ve heard somewhere that you can mix your own wiping poly? Anybody know anything about that? And does it ever make any sense to finish a polyurethane piece by rubbing it out with wax to make a nicer touch and warmer sheen? Lot’s of questions – I know, but wondering about your thoughts and experiences. Thanks! |
