Best low friction surface for table saw extention table
Forum topic by vern posted 534 days ago 924 views 0 times favorited 8 replies Add to Favorites
View vern's profile
vern
1 post in 534 days
534 days ago
I want to building an extention for my table saw what is the best low friction surface? Thnaks for your help.
View markrules's profile
markrules
134 posts in 600 days
533 days ago
Oil.
Virtually no friction whatsoever.
The trick is to get it to stay on the table. Very tricky.
12901 posts in 885 days
533 days ago
Clean Cast iron with wax. Or formica over MDF if you don’t have cast iron.
View BassBully's profile
BassBully
223 posts in 581 days
533 days ago
Formica veneer over whatever substrate you choose.
-- There are three types of people in the world, those who can count and those who can't!
View Nicky's profile
Nicky
78 posts in 576 days
533 days ago
Formica or any non-textured plastic laminate, or how about melamine?
-- Nicky
View USCJeff's profile
USCJeff
804 posts in 553 days
533 days ago
I’m also doing this currently, Vern. I’m removing a cast iron wing on my Grizzly 1023 and building a router extension. I have the plate and hardware, just debating on what surface to use. Seems like Formica is the consensus. I’d like to add a hinged outfeed table in the future. So many projects, so little shop time.
-- Jeff, South Carolina
View woodspar's profile
woodspar
684 posts in 584 days
533 days ago
Also there is something called phenolic plywood that you can buy from Woodcraft. I read about it in ShopNotes vol 15 issue 87. I have been meaning to check this out for making jigs and a router table top and maybe even a table saw support (surround) surface. Anybody tried it?
-- John
View gizmodyne's profile
gizmodyne
1479 posts in 574 days
533 days ago
Melamine works fine. There’s a balance between friction and slick. How slick do you really need? Just enough so it doesn’t bind. Melamine is cheap, glue cleans off it, and you can wirite on it.
View jpw1995's profile
jpw1995
347 posts in 783 days
533 days ago
If you check out Niki’s posts you’ll see that he uses engineered flooring for his router table.
-- JP, Shelbyville, KY
Bookmark And Share This Page
