Boxes!!!! Fastest, strongest, nicest, cheapest way?
Forum topic by Rookie702 posted 03-03-2012 08:43 PM 4316 views 0 times favorited 35 replies Add to Favorites Watch
View Rookie702's profile
Rookie702
43 posts in 2242 days
03-03-2012 08:43 PM
Topic tags/keywords: boxes joints
I get to make a bunch of wood boxes for my moms business, size range is anywhere from 10” D x 12” x 24” to maybe double that. I want these to be strong but cost effective, not sure what material I’m going to use yet, I have some requests for some cedar and maple. I was thinning using metered joints and gluing them together, but creating metered joints can be a hassle, but I don’t want just butt end joints. What are some suggestions, I might have to make a couple hundred over the course of a few months.
Thanks
Jb
35 replies so far
View waho6o9's profile
waho6o9
8164 posts in 2542 days
#1 posted 03-03-2012 08:47 PM
Templates, jigs, locking miter bits for your table router.
Have fun.
View Viking's profile
Viking
880 posts in 3160 days
#2 posted 03-03-2012 08:54 PM
JB;
This is what I have had success with building drawers. A drawer is just a box with no top.
http://www.rockler.com/product.cfm?page=2142
Look at the video on this page also.
Good luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View Loren's profile
10260 posts in 3613 days
#3 posted 03-03-2012 09:32 PM
Box joints. With that number you’d be smart to built the
Woodgears box joint machine.
View Sawkerf's profile
Sawkerf
1730 posts in 3033 days
#4 posted 03-03-2012 10:41 PM
It’s gonna depend on what your Mom can spend and how much (if anything) you need to get after the materials are bought.
Last month, I made 40 minature carpenter tool boxes for centerpieces at some charity dinner. Their budget was really small, and I don’t work for free, so these were made from 3/8” sheathing. I set up a production system and cut all the pieces in a day. One of the charity people came over and sanded everything (80 grit on a ROS) while I assembled them with sImple butt joints and 1” staples. After assembly, we used a pad sander to knock down the rough edges.
They came out looking pretty good considering the material used and the fast and dirty assembly.
Rookie702
#5 posted 03-03-2012 11:35 PM
Wow , look at all that wood, how fun was that?, the boxes I’m going to be mAking are going to be sold so I need the joint s to hold. Up over time. Box joints I think would take to much time. Probably going to use wood and nit plywood
View canadianchips's profile
canadianchips
2600 posts in 2962 days
#6 posted 03-03-2012 11:36 PM
What is going in these boxes ?
What are they going to be finished with ?
Are they to be crates or boxes ?
The smaller ones can be thin lumber to stay lightweight, the ones you say are bigger 2times 10×12x24 is 20×24x48. That is a major size, they would need thicker lumber and become quite heavy.
Balsa is very light and fairly strong.
Rookie702
#7 posted 03-03-2012 11:37 PM
I tiried to build something similar to the wood gears joint machine, let’s just say it failed
#8 posted 03-04-2012 12:07 AM
Oh, pegs. You can rabbet the corners too but making a jig
to drill for whack-in wood pegs is simple enough. Dowel
you buy isn’t consistently round, but you can make it round
by making a dowel plate. Use brad point drills. You can grind
your own.
View northeaster's profile
northeaster
52 posts in 2458 days
#9 posted 03-04-2012 12:30 AM
I just made a couple of 4” x 12” x 4” boxes for hand planes. They involved 1/2” butted hardwood sides (just oiled finish poplar) and slightly recessed prefinished plywood tops/bottoms which were all reinforced/aligned with biscuits. Assembly involved clamping together the closed box, then cutting the lid off before adding non-mortised hinges.
Appearance-wise, it was to me a reasonable outcome which could be improved with better sides and strength-wise, it might work for your small end.
View Jim Finn's profile
Jim Finn
2647 posts in 2887 days
#10 posted 03-04-2012 02:47 AM
I make a LOT (Hundreds) of cedar boxes 11” x 8” x 2 1/2” deep. I just miter the corners and glue. The bottom and top are glued on so the miter joint is pretty strong. I then cut the tops off and hinge them back on. Quick and easy. I also make trunks 24” x 16” x 16” deep (About 50). Miter joints at corners and dadoed in bottoms and tops. (Not glued in place) I reinforce the miter joint on these with a triangular fillet glued to the inside of the corners. I have dropped this completed trunk off of a 2 foot tall table to concrete and it held together just fine.
-- Website is https://craftingcouple.com/
View NiteWalker's profile
NiteWalker
2736 posts in 2542 days
#11 posted 03-04-2012 03:51 AM
Whichever method you go for, once set up for production, things move pretty quickly.
I would probably try box joints, or the rabbeted joints with dowels in place. You could use contrasting dowels as a nice touch.
Rookie702
#12 posted 03-04-2012 05:52 AM
They will be unfinished when I deliver them to mom, she will be decopaugeing them , they are tobe sold as pet toy storage containers
Rookie702
#13 posted 03-04-2012 05:56 AM
These boxes I am to make wont have a top just a bottom and 4 sides, I’d like to miter the corners but so far I have. Not had very good luck with mitered joints, I couldn’t believe how difficult it was to create extact 45degree cuts.
View ksSlim's profile
ksSlim
1274 posts in 2855 days
#14 posted 03-04-2012 06:42 AM
If you don’t have a lock miter bit for your router table, you might look into a chamfer bit for a plain 45 miter.
-- Sawdust and shavings are therapeutic
canadianchips
#15 posted 03-04-2012 01:21 PM
Thanks for more info.
Not sure what you have for tools. This would only need a table saw to do.
A simple rabbet joint (glued) would look much nicer and be stronger than a POORLY done miter .
Always make the rabbet on the longer sides.
Either try to find 3/8” thick boards or if you have band saw, buy 3/4 board and cut it in half. The thickness will be slightly smaller than 3/8”
The shorter sidess can be a little thicker lumber (1/2”) and the longer sides only 1/4” -3/8”. This might help keeping the total weight lighter.
I have made a quick sketch.
showing 1 through 15 of 35 replies
