| Forum topic by RussellAP | posted 472 days ago | 847 views | 0 times favorited | 6 replies | ![]() |
472 days ago |
I’m planning to get some fresh wood, oak and walnut. After I haul it to the mill to have it ripped into the sizes I need for my projects, I’ll need to dry it. Most of the wood will be used for benches that will remain outside. My questions are: 1. Most of the wood planks will measure 3”x4’x14-16” and some will simply be 14 or 16 inch logs quartered. With summer coming on and the associated heat at 90 – 100 degrees, how long do you figure it would take to dry the wood? 2. Are there plans on this site or elsewhere to build a solar kiln? I’d use my attic, but getting them up there would be rather difficult considering their size. I just saw this video and I think I’ll try it with a small amount of lumber. Stack it in the garage, sticker it well, coat the ends and put a couple fans on it. My garage doors are open a lot when I’m working there, so check out this vid and tell me what your thoughts are. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
